Minolta password hi i purchased 2 itec b420 and itec 7222 i am bussy with b420 i nead admin password to get or change ip addres serial no. 42gn02347 please help
spinal
  • 287 Answers
SOURCE: Canon ir C3100 Admin Password
Hello skunkel,
Yes, I believe I can help you. Hopefully these previous admin person did not go nuts with the security thing. But I can help you either way. The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additional functions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Posted on Jul 31, 2008
SOURCE: konica minolta c 200 password
It was 12345678 for our C250 - hope this helps. And sys_admin (solution 1) - You are a complete idiot. Your answer was useless. If you were working for me, I'ld fire you...
Posted on Feb 23, 2009
  • 643 Answers
SOURCE: I have a Toshiba studio 281c, we forgot the ADMIN password, help!
the default password should be "123456".
If u did changed the default password, then u need to enter setting mode 08 - 263 to check or edit the password.
Posted on Mar 10, 2009
SOURCE: Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Posted on Apr 02, 2009
issken
  • 1472 Answers
SOURCE: HP Laserjet 1320n Admin Password has been
joed_calcule
If you changed the password from the default one but forgot the one you set it too all you really can do at this point is set the printer back to the factory defaults. The menu options below will help you do this.
Advanced Printer Settings
Settings tab
Resets = Change all the printer settings back to the factory default settings.
Let me know if you have any more problems or questions
Issken
Posted on Feb 23, 2010
Change c352 admin password
Mr. Gates, yes there is away to change the pw recommended you get a tech out to do it. Change admin pw not over the internet. Should have a paper work to back it up. Big time security thing Hard drive access and stuff
Feb 03, 2015 | Konica Minolta bizhub C351 All-In-One...
Minolta printer IP conflict
try to change the network settings to AUTO ip
1)utilty/counter
2)admin
3)12345678
4)network settings
5)tcp ip
6
0NEXT top bar tap
7)change to auto ip and restart
8)do the same thing again and check if it gave you a new ip address
Mar 23, 2013 | Konica Minolta bizhub Office Equipment &...
Reset password bizhub 211
how can i reset the password for my konica minolta bizhub 211 to remove the maintainance call 2 display?
Nov 21, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
How 2 put the password?
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | SMC Barricade N Wireless Broadband Router...
Minolta c350 password admin
Hi Hamdaoui33,
The admin password should be 1 2 3 4 5 6 7 8
but I'd also try 0 0 0 0 0 0 0 0
Unless someone has changed it from factory setting
Regards
M-PRESS.BIZ
Feb 19, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta 250bizhub is this compatible with bt home hub 2.0 - the ip address previously set before home hub is not being allowed. is it quicker to change ip address or to change hub settings.
if you changed the hub then you have to re assign the ip. to re assign the ip, go to administrattor mode, then in this mode, go to admin 2, in admin 2, go to basic settings, then in basic settings, change the ip of the machine. consult from user manual to know how to get in "Adminstrator Mode"
Apr 07, 2010 | Konica Minolta bizhub C250 All-In-One...
I have a konica bizhub c351, I have changed my network here at the office. This IP address is 192.168.15.50 and now I need to change it to 192.168.0.50. Can you help me?
1.press the utility/counter button
2.select the administrator setting button
3.enter the password 12345678
4.select network setting
5.select tcpip setting
press forward button until you reach the tcpip addres section then you can change the address
Nov 25, 2009 | Konica Minolta bizhub C351 All-In-One...
Changing IP address on computer with router linksy802.11b
access your router with ip.
open internet explorer if your defualt router ip is :192.168.0.1 type this http://192.168.0.1 in addres bar in IE. then neter username admin and password aslo admin
if not accepr blnk user name and passowrd is admin.
then go to ssytem then set ip and follow the procedure.
Oct 06, 2008 | Linksys BEFW11S4 802.11b Wireless...
20 people viewed this question
jasbo
jasbo
