Question about Disney Mix Max Digital Media Player
Can you save mix max movies on sd card
I have successfully converted and encoded my own movies and downloaded them to the mix max. does anyone know if you can save them on an sd card and just insert them when you want that movie. I tried to save the same file that i put on the player onto a card and it wont play, thanks for any help
  • 93 Answers
SOURCE: Disney Mix Max problems
The memory could be corrpt in the player. It some times happens so try reformatting the memory to clear it up. This will erase everything and then you can put your songs and stuff back on it. Here's a link to the manufacturers instructions on how to format the player.
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Posted on Mar 24, 2008
  • 93 Answers
SOURCE: how do you put movies dvds and videos on your mix max mp3 player?
I think I've covered this one before... not sure though so here we go...
First of all DVD's are copyrighted and digitally encoded so that they can't be copied to your computer or other devices. Windows Media Player can't rip them because of this encoding. Not only that if you were somehow able to copy it to the player the Mix Max can't play DVD formatted videos, it can only play WMV (Windows Media Video) formatted videos that are properly "encoded" for play on the Mix Max.
Check out the link below for how to properly encode your videos for play on the Mix Max.
http://digiblue.com/customer-service/faqs/disney/mixmax/index.html
It has a PDF download with instructions on how to properly encode videos so that they will play on the Mix Max.
Posted on May 12, 2008
  • 93 Answers
The Max Clip video cards are already in WMV format but have just have a .smv file extension so it's not necessary to convert them. Besides the Max Clip cards are read only so it's not possible to take the content off of the card to be converted and then placed back on the card. It's more likely that the problem is the firmware version of your player. Try following the directions at the link below for updating the firmware of your player.
http://digiblue.com/customer-service/faqs/disney/mixmax/17.html
If that doesn't work there is probably something wrong with your Max Clip.
Posted on May 28, 2008
  • 93 Answers
SOURCE: sync movies
Check out #7 at http://digiblue.com/customer-service/faqs/disney/mixmax/index.html
Posted on Jun 30, 2008
SOURCE: how to download movies to disney mix max
We got one for our kid too. Follow this link
http://digiblue.com/customer-service/downloads/qsg/DMP9050_WMV_encoding.pdf
Windows Encoder 9 will work but you have to change a lot of settings.
Posted on Dec 31, 2008
I just bought one for my daughter, I can get Videos to work , from the Sync , window media player 10 software , but any time i try to stick in a Sd card , Even a NEW one. It just continuously flashs DO...
Your sd card is to big go down to a 2gb card on the 512mb mix max. Only the mix max plus will support 4gb cards. Also I could never get windows to support files so i used pocket dvd wizard to convert it is 15 bucks well spent and you can convert with the card in the device and save it to windows media to drag and drop in the future.
Nov 13, 2010 | Disney Mix Max Digital Media Player
My Disney Mix Max says that it will take wmv video files from my computer. I've tried it a few different times. It seems to put it on the device but when you try to play it my Mix Max Screen says ''File...
Download and install the Window Media Encoder.
1.1 To make WMV content, you should download Windows Media Encoder from the
Microsoft Website to download Windows Media Encoder 9 Series.
http://www.microsoft.com/windows/windowsmedia/forpros/encoder/default.mspx
File name: WMEncoder.exe
1.2 Then, install the Windows Media Encoder.
2. Procedure of convert video file to WMP9.
2.1 Open the Windows Media Encoder software
2.2 After WMV Encoder start, new session window will be show as below, select the
“Convert a file” Icon and click “OK”.
2.3 Then select and choose the input source (WMV file) and the output file on the File
Selection Dialog Box. After that click “Next”.
2.4 Select “Pocket PC” for the contents distribution and click “Next”.
2.5 Select “Pocket PC standard video (CBR)” for the video and select “CD quality audio
(CBR)” for the audio, then click “Next”.
2.6 Input the contents (i.e. Title, Author, etc) as desired then click “Next”.
2.7 When the Setting Review Dialog Box appear, click “Finish”. Then the input WMV file
will start encoding automatically.
2.8 Then press “Stop” icon as soon as encoding is started.
2.9 Then the Encoding Results will pop up on screen, click “Close” to close the
Encoding Results dialog box.
2.10 Click on “Properties” tab.
2.11 Then the “Session Properties” dialog box will appear on screen.
2.12 click on the “compression” tab and then click the “Edit” box.
2.13 For the Custom Encoding Settings, under “General”, make sure to set the media
types of Audio to “CBR”, “Windows Media Audio 9.1” and Video to “CBR”, “Windows
Media Video 9”.
Then click on the “259Kbps” tab.
2.14 Please be sure you must follow the below setting, otherwise, the DMP9050 will not play
for the WMV file.
Audio format: 128 kbps, 48 kHz, stereo CBR
Video size: 220 x 176
Frame: 30 fps
Video bit rate: 384K bps
Key frame interval: 5 sec
Decoder complexity: Simple
NOTE: Make sure the setting is correct before starting the encoding process,
otherwise, the DMP9050 will not play for the WMV 9 files.
When finish the settings, click “OK”.
2.15 Click on “Apply” to access the setting, then click on “Start Encoding”.
2.16. When the Pop up dialog box appear, click “Yes” to start the encoding process.
2.17 Encoding in progress, the process time depend on the size of WMV files.
2.18 When it is finished, the Encoding Results dialog box will appear. Click “Close” and the
output WMV file can be played by the DMP9050.
if you have Vista with Windows Media 10 or later by default, then you will need to install the Windows 9 library runtimes. It can be done. This works on XP and Vista
Mar 13, 2009 | Disney Mix Max Digital Media Player
Dvd to memory card for mix max
Go get the windows media encoder its free. Set the profile that comes with it up . I get 8 to 10 full length movies on a sd card.
Dec 28, 2008 | Disney Mix Max Digital Media Player
How to download movies to disney mix max
Dec 12, 2008 | Digital Blue Disney Mix Max Princess...
Sync movies
Jun 27, 2008 | Disney Mix Max Digital Media Player
How do you put movies dvds and videos on your mix max mp3 player?
May 08, 2008 | Disney Mix Max Digital Media Player
Ok these are the directions from start to finish.
You need Prism Video Converter and Windows Media Encoder 9 series. You can google both and download for free. You use Prism Video Converter to convert AVI or whatever file to WMV and then use Windows Media Encoder 9 Series to convert the WMV file to a WMV9 file. I know its stupid but if you follow my directions it will work and it cheaper then buying the individual cartridges. Once you have these installed do the following.
Click and open up Prism Video Convertor.
Click to "ADD FILES" on top toolbar. Find and choose the movie you want to convert and double click on the movie and it will add it to the list. Add all the movies that you want to convert. Each one takes about an hour.
At the bottom choose a different output folder. Then scroll through the OUTPUT FORMAT tab at the bottom and choose. .WMV
Click on ENCODER OPTIONS and change everything to the following:
Video Compressor------ Windows Media Video 9
Video bit rate ------------- 4096
Sound Compressor ----- Windows Media Audio 9.2
Sound Format ------------ 128 kbps,48 kHz Stereo CBR
Press ok and then click on VIDEO OUTPUT OPTIONS and change everything to the following
Make sure that there is a check next to RESIZE VIDEO "Shrink or enlarge video to selected size."
Width---- 220
Height --- 176
Make sure that there is a check next to CHANGE FRAMERATE
30.00
Click on OK and then CONVERT when the movie is finished you can move on to the next step
STEP 2
Open Windows Media Encoder 9
click on COVERT A FILE and press OK
Then choose your source file ( the movie you just converted with Prism)
Then Choose a new output file like make a new folder and name it MIX MAX MOVIES and click ok
On the next screen just press ok. Don't worry about the setting at this point because we will change them later.
Name the movie. and click ok and FINISH
Once the converter starts press the STOP button on the top toolbar., its RED, a window will pop up, click CLOSE to close the window. Then at the top of the converter click on the PROPERTIES tab. A window will pop open. Click on the COMPRESSION tab in the middle of several tabs. Click EDIT on the right hand side of the COMPRESSION window.
Now you should see 2 tabs. A GENERAL tab and a 259kbps tab
On the GENERAL TAB change everything to the following:
Make sure Video and Audio are both checked
Audio CBR Windows Media Audio 9.2
Video CBR Windows Media Video 9
Click the 259kbps tab and change to the following. ( If you see something I don't mention here THEN DON'T CHANGE IT )
Audio Format 128 kbps, 48 (NOT 44) kHz Stereo CBR
Video Size 220X176
Frame Rate 30
Key Frame Interval 2 sec
Video Bit Rate 384K (this is a little tricky. MAKE SURE IT SAYS 384K)
Buffer Size 5 sec
Video Smoothness 0
Decoder Complexity Simple
for a total of 521.02
CLICK APPLY and wait a few seconds for it to apply and then START ENCODING on top toolbar. When this movie is finished it will play on your MIX MAX, if it still says that the FILE IS NOT SUPPORTED then you have to go into the setting on the max and change the mass storage setting. There are 2 choices can't remember off hand what they are but choose the opposite one obviously and try again. Also you actually have to go to the movies or video tab on the max player not NOW PLAYING cuz that button is pointless.
any problems email me @ cera1756@gmail.com
I have converted many movies that have worked on both our players so if you follow these directions correctly there shouldn't be a problem.
ENJOY
Jan 18, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
164 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
