Cant delete header N95 8GB
Sounds like data coruption, the easiest and most reliable way fix this is to perfom a factory reset. A factory reset will only wipe the phone contents and leave the Mass memory data in tact, backup all important to to you Mass Memory and perfome a factory reset.
found in menu -> tools -> settings -> general -> Factory Settings.
defualt code is 12345.
this will fix your problem, and about 99% of other software porblems with these phones.
Hi, My HDD6330/17 Go Gear says Loading. I believe there are corrupt files on it but since it won't quite Loading the computer or software doesn't recognize it, so I can format or do anything with it except plug it in or unplug it and let the battery die. I believe the cause of this was that it was used with Windows Media Player 11 twice. Any suggestions would be appreciated.
I had this same problem but when I hold turn off and button ov volume up it's nothing work please help me
i have the exact same problem, and reseting it is not working at all, does anyone know what to do please.
whenever i try to turn on my gogear and plug in the computer it get stuck on the loading screen and my computer cannot detect the usb on the player... i try resetting it and leaving it on charger for 2 weeks and its stilll stuck any solutions?
I've tried resetting it and it brings me to the same "Go Gear" screen. but then stops there. the computer still won't recognize it.
