Question about Hyperkin Retron 3 NES/SNES/Genesis Triple System - Vector Red
Retron 3 No Signal - Hyperkin Retron 3 NES/SNES/Genesis Triple System - Vector Red
How does an everdrive work?
Everdrive is used for console type game systems as Nintendo. It is designed to run roms which are downloaded from internet sites, placed on a SD card, and when you put the SD card in the cassette it reads the SD card as games.
Aug 09, 2014 | Hyperkin Wireless Retron 3 Video Gaming...
Turn off alarm without key fob
First off, you need to know the PIN.
Setting the PIN is as follows:
Think of a five-digit PIN, and write it down. Think of this set of numbers as a password for starting your bike and disabling the alarm during those times when you don't have your fob.
Turn the ignition key on, then off, then on, then off, then on again. Then press the left turn-signal switch twice. Press the right turn-signal switch once, and the current PIN should appear in your odometer.
Be sure the first digit of the PIN is flashing. Enter the first digit of your new PIN by pressing the left turn signal to cycle through the numbers.
Press the right turn signal once to switch to the second digit, and select the correct number with the left turn signal. Repeat this process until your new PIN is entered correctly.
Press the right turn signal once, then turn the ignition key off to save the PIN you selected.
Now, how to disable:
Let's assume for simplicity that your code is set at 31313 and you wish to use the manual disarm of the security system using the directional switches as if you lost your fob and cannot disarm the system.
Your security system will disarm the bike and it cannot be started without deactivating the system first.
If you are unsure of what the manual code is refer to the top of this page or check with your dealer and set one if it has not been set by them.
Again this is based on your code being 31313 just to make it easier to understand.
1. Turn the ignition to Accessory.
2. Press both turn signals. (security light should flash rapidly)
3. Press left turn signal button 3 times (the 1st "3" of the PIN). Press right turn signal button 1 time (to "set" the code number).
4. Press left turn signal button 1 time (2nd number of PIN). Press right turn signal button 1 time.
5. Press left turn signal button 3 times. Press right turn signal button 1 time.
6. Press left turn signal button 1 time. Press right turn signal button 1 time.
7. Press left turn signal button 3 times. Press right turn signal button 1 time.
Security light stops flashing and security system is disarmed.
If you've changed the number, use your new number instead of 31313.
Dec 25, 2013 | Harley Davidson Motorcycles
Retron 3 nes controller ports
I have no solution but having the same problem. Did you ever get it to work? And if so how?
Jan 09, 2012 | Hyperkin Retron 3 NES/SNES/Genesis Triple...
I have a model nus-001(usa) that was purchased some years ago. my grandson would like me to bring it to Spain where he lives with the games so he can play it. Will it work on the different electrical...
You can get a power adapter for the 64 that will drop the voltage for you. You will also have to get an video converter box that will convert NTSC to PAL B/G. You should be able to get a traveler power kit that should have what you need. The adapter should convert the power down. Don't use just the adapter unless the 64 says it can handle a 240v power. the usa use a 110 to a 120 power grid and Spain use a 240v power grid.
The retron 3 wont play nintendo 64 games. It olny will play nes snes and sega genesis games.
Sep 10, 2011 | Nintendo 64 Console
Super Mario game loads, the battery-operated wireless controllers do absolutely NOTHING. Cannot start the game -- get it onscreen and it goes through its little demo but the controllers just won't get...
I don't know a lot about this console (the Retron 3), but the game sounds like it works fine, try using a different third-party console, I recommend the Retro Entertainment System, it's only around $20 - $25 on eBay, try a different NES game, if it doesn't work, than it's probably the controllers, get replacements, or the batteries are dead.
May 06, 2011 | Hyperkin Wireless Retron 3 Video Gaming...
Hi i have a 2004 sv1000s not getting any fire from the spark plug line i put the bike in dealer mode an i got c41 what dos that mean ?
GSXR Fuel Injection (FI) Code List:
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR (1000 ONLY)
heres a list of fault codes hope it helps
John
Jan 04, 2011 | 2003 Suzuki SV 1000 S
How do i turn off the sound on the alarm
Setting Audible signal
This function gives an audible signal when the coffee is ready. The factory setting is "On".
  • The display (q) will show " " with the current time.
  • To turn off the audible signal :
  • Press prog button then the 1 - 3 cup button (p).
  • The display will show "YES": indicating the audible signal is on.
  • To turn the audible signal off:
  • Press the 1-3 cup button again.
  • The display will show "NO": the audible signal is off.
  • Press prog button to confirm.
Sep 24, 2010 | Krups FMF5-14 Stainless Steel 10-Cup...
2006 hundai elantra P2270 code. If this is an O2 sensor, which one?
Possible O2 sensors:
P2270 O2 Sensor Signal Stuck Lean Bank 1 Sensor 2
P2271 O2 Sensor Signal Stuck Rich Bank 1 Sensor 2
P2272 O2 Sensor Signal Stuck Lean Bank 2 Sensor 2
P2273 O2 Sensor Signal Stuck Rich Bank 2 Sensor 2
P2274 O2 Sensor Signal Stuck Lean Bank 1 Sensor 3
P2275 O2 Sensor Signal Stuck Rich Bank 1 Sensor 3
P2276 O2 Sensor Signal Stuck Lean Bank 2 Sensor 3
P2277 O2 Sensor Signal Stuck Rich Bank 2 Sensor 3
P2278 O2 Sensor Signals Swapped Bank 1 Sensor 3 / Bank 2 Sensor 3
This is Bank 1 (closer to the dash panel) Sensor 2 (located after the catalytic converter).
Note: A malfunctioning front oxygen sensor may cause fuel trim codes to set.
  1. Several Diagnostic Trouble Codes use specific terminology to refer to sensor location. The illustration and key below explain the following terms:
  2. Engine BANK Bank 1 is closer to the dash panel, (also referred to as RH or right hand). Bank 2 is closer to the radiator, (also referred to as LH or left hand).
  3. UP Refers to Sensor 1 or "front sensor". It is located closer to the exhaust manifold and before the catalytic converter.
  4. DOWN Refers to Sensor 2 or "rear sensor." It is located after the catalytic converter.
  5. The following examples show how to interpret oxygen sensor terminology:
  6. B1/S1 = Bank 1/Sensor 1 = Dash panel side, BEFORE the catalyst or "upstream"
  7. B2/S2 = Bank 2/Sensor 2 = Radiator side, AFTER the catalyst or "downstream"
Aug 06, 2010 | Hyundai Elantra Cars & Trucks
Hyperkin Retron 3 NES/SNES/Genesis Triple System - Vector Red Logo
59 people viewed this question
Top Hyperkin Video Game Consoles & Games Experts
James Wishart
Are you a Hyperkin Video Game Console and Game Expert? Answer questions, earn points and help others
