Question about RCA F27442 27" TV
RCA DECK133R tv/dvd
I am trying to program my DISH remote for my 13" RCA LED tv/dvd. It is not listed in all the internet pages for manuals, etc., nor is this model # in my DIsh system.
4 Suggested Answers
poacher1
  • 10 Answers
SOURCE: SETUP RCA F38310 TO DISH NETWORK
using your Dish Network box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. Or you can connect your Sattelite to the antenna A or B input jack on the back of the set and set the tv input to antenna
Posted on May 13, 2009
  • 3 Answers
SOURCE: i need a list of codes to program a rca tv to dish
you need dish network remote control manual for codes.
Posted on Dec 05, 2010
gopakumarg43
  • 74473 Answers
SOURCE: I cannot program my tv to the remote
Try a code search method. If there is a code in the remote controller's programmed memory, it will respond. Otherwise, buy a new remote control. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Posted on Nov 26, 2013
Working my RCA T.V with my Dish network remote
Download a list of programming codes for your specific "Dish" remote that are applicable for RCA TVs:
https://www.mydish.com/support/products/remotes/how-to/program-to-tvother
The RCA brand has many codes since it has been built by different manufacturers over a long time. Try each one.
If no RCA codes work, and it is a newer LCD or LED TV, try programmable codes for SONY televisions, as the RCA brand seems to use the same codes as SONY for some features like Power/Volume Up Down/Channel Up Down.
Best of Luck.
Nov 15, 2017 | RCA Televison & Video
How to program an rca tv remote to rca tv
Hello
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
Jul 05, 2011 | RCA 3-Device Universal Remote with...
I dont have a remote for this tv because it was given to me yrs ago and I've always just used it for dvd use or vcr use for my little 3 yr old. I was trying to hook up my dish network to it last night and...
Just program the remote to control it, the most likely code will be 566.
Below are two links the first will give you codes and help you address the remote, the second will help if there is still no picture. http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
DISH Network Customer Service
Dec 28, 2010 | Philips Magnavox 20MC4304 20 in....
How to program a rca rcr451 remote
1. Manually turn on the component
you want the remote to control
(TV, VCR, DVD, satellite receiver
or cable box).
2. Locate the enclosed Code Lists.
Find the list for the component
you wish to program. Find your
component’s brand. You will see a
listing of four-digit codes for each
brand. If your brand isn’t listed,
use the Manual Code Search
method to program the remote
control. (Refer to page 6 for
Manual Code Search method.)
3. Press and hold the component key
(TV, VCR, DVD, SAT·CBL) you
wish to program. The LED
indicator light turns on and remains
on. If you release the component
key any time during the Direct
Code Entry procedure, the LED
indicator light blinks four times,
and the process is exited.
4. While holding down the component
key, consult the Code Lists for the
four-digit code that corresponds to
your component’s brand and use the
number keys (0-9) on the keypad to
enter it. While you are pressing the
numbers, the LED indicator
light turns off.
5. After the fourth number is entered,
the LED indicator light turns on. At
this time, release the component key.
If the LED indicator light turns off,
you have entered a valid code and
have followed the correct procedure
for Direct Code Entry.
If you enter a code number that is
not in the Code Lists or you do not
follow all of the steps for Direct
Code Entry, the LED indicator light
blinks four times when the
component key is released. This is an
indication that a programming error
has occurred. In that case, repeat the
Direct Code Entry process from step
3 and try the next code listed.
Throughout the programming
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
6. To confirm that the component key
is programmed with the correct
code for maximum functionality,
test the component. Attempt to
control a variety of the
component’s functions with the
remote. If some of the features of
your components do not work, try
programming the remote with a
different code in the list until you
find the code that allows the
remote to control the majority of
your component’s functions.
Different codes can provide
different levels of functionality.
DOWNLOAD the full manual with codes for free at: http://www.replacementremotes.com/RCA-Manuals/Download-FREE-RCR450C-MANUAL-OPERATING-MANUAL.html
Aug 11, 2010 | RCA Universal Remote Control
Dish network remote to run RCA DVD player
I had rca remote that did not recieve ir signals but rf signals instead. Check online with rca or in owners manual for what type of signal factory remote sends. The dvd player I had was 5 dvd and that was the case. Dish might have an option like direct tv where you can program rf signals as well. Call dish network support or look online
Apr 25, 2010 | DISH Network IR Remote Control
Set t.v /remote to work with other components
Do you have a Sanyo Universal Remote ? If not, you program your dish 500 remote for these.
Sep 16, 2009 | Sanyo DS31590 31" TV
Can I program my dish network remote for a rca
Try the RCA codes listed in the code book that came with your Dish remote. You will want to use the "AUX" button at the top of the dish remote. You will likely NOT get full functionality if it works at all, however, there is a chance you'll be able to change the channels and power the converter box on and off.
If the codes you have are segregated into categories of different devices, i.e. TVs, DVD players, etc. You probably will not be successful.
Also, there should be instructions in the remote manual that will tell you how to search all codes that are stored in the Dish remote.
While this may not solve your problem, I hope I've given you helpful information that will allow you to make an informed decision as to where to go from here.
Let me know if I can be of further assistance.
May 18, 2009 | Televison & Video
Code list
Programming remotes for your devices (TV, DVD players, digsat/cable boxes/DVRs, etc) can be done often in an automatic (auto-code search) or manual (you input the code) mode.
Here are some pages that will help you choose the automatic and manual mode.
http://www.ehow.com/how_9191_program-rca-universal.html
http://www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button
http://www.thompsontv.com/rcarc.html
http://tv.manualsonline.com/manuals/mfg/rca/rca_universal_remote_product_list.html
Nov 08, 2008 | RCA 3-Device Universal Remote with...
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
grateful,
kay
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
I'm missing the instruction manual for my RCA RCR460 remote control. I need the manual set-up instructions, and a list of all the potential codes to sync up to a Toshiba or Mitsubishi DVD player. Any help...
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box). Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR, DVD, SAT·CBL, ON·OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained. 2. Press and hold the component key (TV, VCR, DVD, SAT·CBL) you wish to program. The LED indicator light turns on and remains on. 3. While holding the component key down, press and hold the ON·OFF key. The LED indicator light turns off. 4. After holding down both keys for three seconds, the LED indicator light turns back on. 5. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control. 6. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Press Stop when TV turns off.
Jul 06, 2008 | RCA RCR460 Remote Control
RCA F27442 27" TV Logo
108 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
