Question about Whirlpool GHW9400 Duet Washer
Started getting an F2 error code
About a month ago we started getting and F2 code on our whirlpool duet. We did not have a manual so we would press pause twice then it would continue the cycle and most of the time finish it. Now it won't even spin at all. You start the washer and you can hear it start and running but it doesn't spin the clothes. It will again stop and indicate an F2 problem. The door also stayed locked and won't unlock. Please help!
I looked up the F02 code online and this is what it says:
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Hope that helps.
Posted on May 23, 2009
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
Potential Causes
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brand New Whirlpool Duet 9450 Error Code PF
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Jul 25, 2009 | Dryers
My Whirlpool GHW9100LW started making a strange sound and not wanting to finish the spin cycle about a month ago. up until now it will finish off and on. I cleaned out the thing that twists off in front...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Started Duet without water turned on. Now have error code.
go here and find your manual this will help
www.whirlpool.com.au
Jun 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9100 starts cycle then stops & wont drain
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
Mar 24, 2009 | Whirlpool GHW9100L Front Load Washer
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
553 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
