Question about Kenmore 24032\24036 Top Load Washer
During agitation it sounds like it is slipping and grinding
Just a few days ago, I noticed that when the agitation cycle started, it sounded like grinding every few seconds.  What could this be?
  • 1 more comment
  • grecianqueen Oct 18, 2007
    I don't see any water leaking in the tray.  The spin cycle works fine.  It seems like the sound is coming from the area where the agitator is.
    Iam listening to it now.  It is in the 2nd cycle agitation.  It will agitate for a few moments fine and then start to grind.
  • Anonymous Feb 10, 2008
    I have a Kenmore 70 series top loader that grinds and will not move the agitator, what do you think it is?
  • 240 Answers
It could be a number of issues really.  Smaller issues could be something under the agitator, etc, to moderate problems, like a motor coupler, loose basket, etc.  Could also be a major problem like a motor or transmission.  A lot of times its the motor coupler or pump making the noise.  Both are pretty easy to replace.  Maybe some more information.  Do you happen to know where the noise is coming from?  Is it coming from the front of the cabinet or in the basket area?  Any small water leaks?  Does the spin cycle work ok?  Let me know some other information and maybe we can narrow down the problem to one particuliar area.   Jim
Posted on Oct 18, 2007
Noisy during agitate cycle whirlpool washer
Originally posted as solution to Kenmore 24992300 failure to agitate and loud whirring noise during spin cycle.... Hope this helps:
The problem as I noticed it was that the washer would start making a super high-pitched and very loud whirring noise during the spin cycle, and that when I would open the lid, the drum would not be spinning, but when I would close the lid, the drum would start spinning. I was okay with this during that load but after reading here and taking it apart, I realized what had happened:
The agitator dogs are supposed to have a 3-toothed profile on each one, but they become worn over time due to being made of a soft plastic. The dogs should "throw out" into an inner ring gear during normal operation, turning the entire drum. But when they became worn enough to slip, they would still throw out, grinding them at very high speed into the inner ring gear. Since they are made of a softer plastic than the gear, they were just getting more and more worn.
I assume the way this was supposed to fix itself was that when the outer tooth on the dog became worn, the next one would engage, but that didn't happen.
Because the dogs are made of such a soft plastic, I was able to cut a new tooth profile into each one, so that when they were put back in they would function correctly. It takes very little effort and a few minutes with an x-acto knife to cut the right profile.
I'm going to buy the replacement dogs, which being a manufacturer substitute will hopefully be made with a better tooth profile, from harder plastic, or both.
As another note, who knows how long the dogs weren't engaged correctly during agitation, causing clothes to sit without really being washed, but without the high pitched air raid siren. So probably a good idea to replace or repair them immediately, even if you can get it to work intermittently.
Sep 12, 2013 | Sears Parts Direct Whirlpool 4313896...
My cabrio top loader high efficiency low water washer is making noises
sounds like water has got past the seals and into the upper bearing.if this is the case you will hear a loud roaring noise during the spin cycle.not a cheap fix!
Dec 17, 2017 | Whirlpool Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
Fisher and Paykel ECS Washing machine agitator slipping?
There are "dogs" under tops of some agitators. Easy to repair. ID them and pull up washing machine parts at Amazon. Dogs are by themselves(3 hard plastic gadgets) but better to buy the whole thing that hold the dogs. Usually under $10.00.
Apr 25, 2017 | Fisher Washing Machines
Our whirlpool 5232d top loader is making grinding noises at the beginning of the wash cycle and the agitator seems to be slipping on its spindle though a little further on into the wash cycle the grinding...
Sounds like a bad transmisson or you room temp is below 30 making the oil in transmisson like tar. Or its just the dogs or top gears in the adj.
Nov 11, 2009 | Refrigerators
Grinding noise while agitating.
possible foreign substance under agitator
Feb 26, 2009 | Admiral AAV7000A
Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Jan 26, 2009 | Amana LWA40A
Kenmore top loader washer noisey agitator
it sounds like the gear dogs in the agitator. pop he top of agitator and check. its a easy repair.
Aug 28, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
138 people viewed this question
Sal De
 Brian Main
Brian Main
