Question about NEC Electra Elite 32D-1 Corded Phone
When people dial our main number it rings on there end but does not come through. Phone system is a NEC Electra Elite 48
  • arcraig5933 May 18, 2009
    I have an NEC Electra Elite 48 phone system with 4 inbound lines. When people call our main line it rings non stop and the does not ring on our end. This problem was on and off and now is a perm one. Please explain in simplified terms with troubleshooting tips I can use.
    I can dial out on that line not inbound. I have used a different phone at the jack and it works however it dose not work inbound
    Sergeant:
  • 326 Answers
Its a clear problem of the line.call the service provider of the phone and get new line fixed. this will only solve your problem. thanks.
Posted on May 19, 2009
    Genius:
  • 1,847 Answers
Plug in a different phone and try dial the main no. check it ring back on the other side.
If the same isssue persist contact the telephone company.
Else replace the phone.
Let me know the status
Thanks
Kevin
Posted on May 18, 2009
    Brigadier General:
  • 3,917 Answers
You need special NEC software. The program is called SAT and it is proprietary. The version of SAT that you need is dependent on what software level your 48 is at. Also you will need a MIF-M card to allow pc programming, otherwise you have to do it through the telephone set.
Thank You
How do i make the nec electra professional phone not ring
I think you have change its internal setting so reset your phone again so its again setup your phone and your problem has been removed like phone ring.
Nec sv8100 IPK DTerm phones Inlinecom
Aug 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
How do change the outgoing "Night Mode" message in the Voice Mail System on NEC Electra Elite DTU 32D-1?
If you are using an Active Voice product (typical w/ NEC) you need to change the hours of operation on the voice mail system. "Night Mode" only changes the ringing characteristics of the phone system and where calls ring, not the greetings that play on the voice mail. The voice mail plays a particular greeting (Day/Night/Holiday) based on the time of day specified in the schedule. The system administrator for the voice mail would have to make this change.
Jan 24, 2012 | NEC Electra Elite 32D-1 Corded Phone
My voicemail has been set up, but it will not answer calls.. it rings and then rolls back into the main message for the office
Set your Call Forward Busy/No Answer to go to voice mail ext. as follows: Lift the handset, dial 4 then 3 followed by the voice mail ext. (the number you dial to retrieve voicemail messages). Hang up.
Jul 26, 2011 | NEC Electra Elite 32D-1 Corded Phone
Cant change time on nec etw phone
Try this:
NEC Electra Telephone System
Changing the time on a Electra Elite & Professional system must be done from the "main" or primary phone. It is usually extension # 100. 1.- Press "FEATURE" 2.- Dial "9#" 3.- Enter hour and minute 4.- Press "RECALL" to change AM/PM setting 5.- Press "HOLD" to change the calendar setting 6.- Press "RECALL" to change the day of week 7.- Dial "#" to move the cursor to day of month field 8.- Enter day of month 9.- Press "RECALL" to select month 10.- Dial "#"to move the cursor to year field 11.- Enter last 2 digits of year 12.- Press "FEATURE"
Carl
Nov 06, 2009 | NEC Electra Professional ETW-16DC-2
HOW CAN I ANSWER THE PHONE WITHOUT PRESSING ANY BUTTON?
It has to do with a program called ringing line preference. Program # 4-11. Check out www.wedophones.com/Manuals/NEC/Electra%20Elite%20IPK%20Programming%20Manual%20-%20Document%20R%204.pdf
If you happen to have an Electra Elite 48, 192 or IPK this manual can show you how to program that feature. Don't take it lightly though, you can jeopardize your system if you do not know what you are doing.
Sep 08, 2009 | NEC DTH-8D-1 Corded Phone
Line rings does not fo to voice mail
The call forwarding was canceled; try this
1. pick up handset or press speaker
2. dial the code for call fwd busy/ no answer (default code is 744)
or press the forward function key
3. dial 1
4. dial the extension (lead number of your voice mail)
5. press speaker or hang up
May 20, 2009 | NEC Lands Phones
Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Mar 12, 2009 | NEC Electra Elite 32D-1 Corded Phone
No dial tone on a nec dtu
The NEC phone is probably a business multi-line digital phone, requiring a phone 'back-end' system. Will not work on an analog 'home' phone line.
Feb 16, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
I have an electra elite phone system how can i change my recorded message from a different location?
Dial a number (outside phone line or extension number) that rings direct to voicemail. Once you hear a greeting, the typical access is "9" + your extension, after which you will likely be prompted for your password. If you are within your phone system, the softkeys will now work just like you were at your own phone, otherwise you will be prompted with a menu.
Dec 31, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
I have sixteen button NEC Electra ELite Multiline Telephones in my office-
Here's how you adjust the time:
1. Press <TRANSFER>
2. Press <CONF>
3. Press *
4. Press <TRANSFER>
5. Press <CONF>
6. Press #
7. "CAT MODE" displayed on LCD
8. Press <REDIAL or LNR/SPD>
9. "COMMAND" displayed on LCD
10. Press 02
11. Press <RECALL>
12. Press 2
13. Press <RECALL>
14. "02>2>Current Time" displayed on LCD
15. Input correct time using military time (HH MM SS)
16. Press <CONF>
Nov 13, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite 32D-1 Corded Phone Logo
59 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
