Question about Sony KDL32EX301 32 in. HD-Ready LCD TV
Kdl32ex301 ghosting horizontal lines - Sony KDL32EX301 32 in. HD-Ready LCD TV
How do I get rid of horizontal lines that ghost the image on my screen?
The t con board or the LCD panels is faulty. Can confirm only by replacing the Tcon board.
If you wish to know more about Tcon board problems and troubleshooting then check the following link.
http://electro-medical.blogspot.com/
Oct 03, 2016 | Samsung LA Televison & Video
How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
Sep 13, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My samsung la40a650a1fxxy is ghosting and has horizontal lines
prob a loose wire from the inventer board to the backlight,need to open andsee.should be easy fix
Mar 19, 2013 | Televison & Video
What if my samsung tv has ghosting images/horizontal
thats a convergence issue I will need the model number of your samsung in order to assist further with the issue.
Ghosting on one side of screen on start up, then goes away
The T-con board failure or LVDS cable connection loose may cause the problem, you can try to reconnect the LVDS cable first.
Knowledge obtain from: Real case of repair by myself.
May 08, 2010 | Sony KDL-52XBR9 52 in. LCD HDTV
Ghost lines horizontally (looks dirty) when making multiple copie
Check the cleaning blade of the OPC drum,the image transfer unit.
Aug 17, 2009 | Canon Office Equipment & Supplies
Horizontal ghost lines across screen
Seems that it is an issue with your video card, Please update Driver for Video card and it that does not help, it is the time to replace the Video card.
You can get your driver from support.dell.com and please enter your service tag to download the driver
May 25, 2009 | Dell M781S Monitor
Two vertical lines one at 1/3 screen the other at 2/3's of screen
I have not fixed it yet. But I have identified the chip that is causing the problem. If you have a service manual scan it and post it please, so I can show you the chip.
Aug 04, 2007 | Toshiba 57H81 57" Rear Projection...
Jagged horizontal blue lines everywhere
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 10, 2007 | Mitsubishi VS-45609 TV
Sony KDL32EX301 32 in. HD-Ready LCD TV Logo
46 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
