Question about Husqvarna Garden
Cranks but no spark - Husqvarna Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Check safety system first, then suspect a bad coil. should of mentioned what kind of engine, makes it easier to tell you where to look for the kill wire
Posted on Dec 28, 2013
Cranks but will not fire
Did you check for spark?
Hold onto the spark plug wire and if you don't get the heck shocked out of you then problem is ignition. *** NO DON'T HOLD ONTO THE WIRE ***. Remove the spark plug stick it into the spark plug wire and make sure it it grounded good and have some one crank it if you can not see the spark plug gap while cranking it. You see a spark then problem is it is not getting any gas and find out why. If no spark then problem is ignition and then find out why....
Aug 02, 2015 | Garden
Where is ignition module on 1977 FLH
Try cranking it with the spark plugs in and the wires not plus into them. Use a extra plug and check it. You might get spark cause the motor need to have compression to spark. Your crank position sensor might be bad.
Aug 25, 2014 | Motorcycles
Car is fireing an getting gas but want crank
if it cant crank there is no spark , there will never be fueling.
The starter is first. does it crank over the crank shaft fast.
yes, i must guess.
then next is spark, with no spark , EFI cuts fuel. (no fires)
so if it cranks the crank shaft fast (look) then check spark now.
on all cylinders not just 1.
then post. results for step 3.
Jun 23, 2014 | 2000 Hyundai Elantra
Troubleshooting engine
Yes you are heading in right right direction. Check to see if there is spark out of coil. Spark at coil means replace distributor or rotor. No spark at coil replace ignition module or crank sensor good luck. Oh yea crank sensor is cheaper i would try that first if there is spark out of coil.
Apr 18, 2014 | 2001 Ford Explorer Sport
My 1991 ford festiva wont crank replaced fuel pump and screen and fuel filter and fuel pump relay still wont crank and we have pushed the reset button what now help pls
Won't crank? Problem is with starter-have it tested.
If it cranks and won't start, check for spark at one of the spark plug wires. If no spark when the engine is cranking, the ignition circuit is the problem.
Mar 01, 2014 | 1991 Ford Festiva
Cranks won't start
First you must check to see if engine is mechanical sound by performing a compression test. remove the spark plugs install a compression gauge in the spark plug hole and crank engine about 4 cycles compare readings to all cylinders reading should be around 125-150 psi readings in the 50 psi range possible jumped or broken timing belt. If engine is mechanically sound test for spark at the spark plugs use a spark plug laid against valve cover and have some one crank it over look for the spark to jump the gap. A no spark problem is internal in the distributor.
Nov 07, 2013 | 1995 Honda Accord
Cranks but doesnt start
I am a self emplyed mechanic, if a motor cranks but does not start, that is not a starter, you need to see if you have gas or spark . is there a buzzing in the gas tank when you turn the key. if so then you have gas. now you needto see if you have spark. need 2 people to do this . pull a spark plug wire and stick a screw drive in the boot and crank the motor please stand back,and look for spark. if you have spark. then you need a crank position sensor thank you ted
Sep 08, 2012 | 2004 Dodge Stratus
No spark
Yes. No crank sensor signal usually means no spark. The ecu has to receive crank position to set spark timing. I think you've really hit a big problem. You may need to get in touch with some people who have done this mod. I've always heard it's best and easiest to swap the engine with its ecu and the wiring harness into another car. Or something more compatible with that jdm engine.
Jul 27, 2012 | Honda Civic Coupe
I HAVE A 93 COROLLA THAT CRANKS, BUT DOESN'T TURN OVER .. WHAT COULD BE THE PROBLEM???
if it cranks but wont start check for spark by sticking sparkplug in end of wire rest on block have someone crank if there is spark it is a fuel pump issue if no spark check crank sensor
Aug 17, 2009 | 1993 Toyota Corolla
Garden Logo
24 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
