Question about Tappan Ovens
TGF336AW burners won't light
  • Roland Duby
    Roland Duby Feb 16, 2014
    I figured it out, the gas was turned off to the stove outside
I just refilled my propane gas tanks and gas is coming through the top burners but there is no flame. I hear the clicking sound it makes when the pilot light ignites but no flame at all. What do I do ?
air won,t burn ther is air between the tank & the burner try using putting a flme at the burner then tun on the burner it should start after the air passes through the hose
Nov 23, 2013 | Whirlpool SB160PEE Gas Single Oven
Why won't burners stay on
Alguien puede ayudarme con el diagrama electrico del horno imperial
gracias
Jun 20, 2013 | Imperial ICVD-1-H Turbo-Flow Gas Single...
I melted some butter in the oven, it dripped into the burner holes and now they won't light.
i would let do this by specialist,to clean the burner.
butter can also ignite or you can get gas bubbles,not safe
Jul 26, 2012 | Stoves Ovens
Oven won't light
ck thermal coupling see if its to far from pilot light or burnt out
Feb 18, 2012 | General Ovens
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
Burners work fine, pilot light in oven is on, but oven won't ignite
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Aug 28, 2011 | Ovens
I have a frigidare gas stove I have changed the ingnitor bar and it still wont light, it seems if there is no gas coming in to the oven. Altough the top burners still work
Good day!!!
Your pilot light might have gone out. If this is the case then you have to re-light it. If the pilot light won't stay lit, then you might have to adjust the thermocouple or move the pilot light closer to the burner.
I hope this information will be helpful..
Thanks for using fixya..Have a nice day!!
Aug 27, 2011 | Explorer Appliances Ovens
The pilot light is on but the burner won't lilght
When the oven lighting mechanism lights the gas the flames heat a temperature sensor that, once hot, increases the pressure in the sensor's copper pipe and opens a safety valve to allow gas to continue to flow (It's made like this so, if your flame gets blown out, the sensor cools and cuts off the gas supply, making it safe from gas leaks). These sensors occasionally fail, and very sensibly "Fail safe" - No pressure in the sensor pipe, the valve won't open and there is no gas to the burner.
If you take a look inside the oven at the back where the burner is, you will see the sensor, usually the bit that is in the flame is cylindrical, about an inch long made of metal about 3 or 4 mm thick, tapering at the end. It will be held in place by a nut that fits on a thread at the base of the sensor. Running from the sensor is a copper pipe that runs to the cutoff valve. Unbolt the sensor and withdraw it from the hole it is mounted in, trace the copper pipe back to the valve (where it is usually screwed into the valve with a 10mm connector that looks like a car brake pipe connector. Unbolt from the valve. These sensors are widely used on most gas appliances (Boilers, gas fires, cooker hob burners and patio heaters all use the same kind of sensor). You should be able to get a replacement from any gas appliance service agent. If you go into a shop, take it with you. The only thing you need to do is make sure the replacement you get is long enough. If you are offered one that is slightly longer, that
Jul 19, 2011 | Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
Ovens Logo
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Tappan Oven Expert? Answer questions, earn points and help others
