Question about Ncstar Aqpfls 120 Lumen Flashlight Laser Combo Light ()
What do you do if the flashlight stops working on theNcSTAR
The laser works but the flashlight just wont come on
Our flashlight stop working even with a brand new battery
The bulb may be blown. If the bulb is ok then you may have a broken wire, corroded connections or a bad switch.
Jul 20, 2014 | Eveready 6V Super Heavy Duty Lantern...
Htc camera and flashlight has stopped working
htc camera and flashlight not working when using camera phone stop working
Jan 10, 2013 | HTC Desire Cell Phone
My system plays cd's dvd's but when i put a ps3 game in the disc wont show therefor im not allowed to play any games by disc
The Playstation 3 is a wonderful video game console, however, with heavy usage, the laser does eventually burn out. The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the game will stop reading altogether (even though movies sometimes still work). Eventually movies will stop working and the whole laser will eventually die.
The following website sells PS3 lasers and also performs repairs:
http://store.richspsxparts.com/pl3isnotrega.html
Jun 16, 2011 | Sony Playstation 3 (PS3) Console
Put new batteries in it,turned it on and still wont work,you think it might be the bulb
Before replace the bulb, check for rust or dirt inside the electrical contacts. clean it. if still wont work, replace the bulb.
sammyc47
Feb 22, 2011 | MagLite 4 Cell C Flashlight Black
Cd drive motor wont spin properly
...see if the laser lens not dirty and working fine...sometime if the laser lens can read the disk then the motor stop working...and in the information screen LED say "NO DISK"...
Apr 29, 2009 | Electronics - Others
I have a glock GLT 22 laser/light - only the laser worked, changed batteries, now nothing works!
I had the same light what I did not know about the light was that the bulb will burn out in about 5 to 7 uses some times or if you droped it or hit the light on some thing hard buy a new bulb for it and buy a new battery. Just because if you change the battery it could be bad as well.
Jan 01, 2009 | Laser Glock Tactical Light W/Dimmer
Problem with PS2 SCPH 75001
You will need a Magnifying glass, Flashlight, Toothpick, and Paper towels.
What you need to do is access your laser, and make sure the laser optics are clean. Using the magnifying glass and flashlight, inspect the lens for dust, smudges and lint. Using a Toothpick with a small piece of paper towel swab the lens to clean it. If you need a Cleaning solution, use Windex. If this does not solve the problem, Get a new KHS-400C laser from Ebay. When the new laser arrives, you will need to remove solder blobs from the ribbon circuit strip on the bottom of the laser. These are two small solder blobs near the Ribbon cable connector. I do this with soldering iron, Vise ( to hold the laser), and Solder wick.
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
My Sony PlaySatation2 console wont read any games on PS2 discs.
Check this web site out, this will help you, this problem happens alot so dont worry you should be able to do it yourself. http://arstechnica.com/articles/paedia/hardware/ps2.ars/1
Mar 12, 2008 | Sony PlayStation 2 (PS2) Console
Ncstar Aqpfls 120 Lumen Flashlight Laser Combo Light () Logo
Top NcStar Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a NcStar Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
