Question about Sharp Televison & Video
The number of memory ic is erase - Sharp Televison & Video
    Problem Solver:
  • 12 Answers
Get the Brand and model # of the unit ,buy circuit diagram theire you find the IC number you have looking for.
Posted on Dec 28, 2013
I only want to use the PC input ext4. Is there a way to lock it there?
After selecting the desired input, it should be there inside the memory IC of your TV, even after you switch the TV OFF. If it do not store the LPM {Last Position Memory}; means, the main system control memory IC inside your TV is faulty, and should be replaced.
This is an EEPROM [Electrically Erasable Programmable Read Only Memory). It is a very Small IC; can be located very near to the main system control IC at the main board. Contact any service technician to replace it.
It will look somewhat like this.
25828494-jsorn3kr3nqsupvrl22j3clf-4-2.jpg 25828494-jsorn3kr3nqsupvrl22j3clf-4-5.jpg If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 19, 2015 | Televison & Video
How do I delete a recording off my Sony Sony - ICDBX140 - 4GB
  1. Slide the HOLD?POWER ON/OFF switch in the direction of "POWER ON/OFF" to turn on the IC recorder, or towards the center to release the IC recorder from the HOLD status. The stop mode window appears.
  2. Select the file you want to erase when the IC recorder is in the stop or playback mode.
  3. Erase a selected file. When the IC recorder is in the stop mode, press and hold ERASE.
    When the IC recorder is in the playback mode, press ERASE.
  4. Press ERASE. "ACCESS" appears in the display window and the selected file will be erased.
    When a file is erased, the remaining files will advance so that there will be no space between files.
Hint
  • To cancel erasing, press souni_stop.png(stop) in step 3.
  • To erase a part of a file, divide the file into two files first, and then proceed with steps 3 through 4.
Mar 10, 2015 | Sony Video Cameras
When I try to auto search the channels it says erased after every number
Its main system control memory IC is damaged. Check and replace it.
Jul 14, 2013 | Hitachi 42HDF52 Television
I am trying to get the tv to go to channel 116 so it will work with my satelite but it will only go to channel 99
Hello
The channel may have been erased from the channel memory by the ADD/ERASE feature. Add
the channel to the channel memory
To get the erased channels back to; you have to do it manually.
Enter its 'Menu" and come to "Set Up"
Press [UP] or [Down} buttons on the remote control to select and hilight [ADD/ERASE]
Press [>] of [<] buttons on the remote to select ADD or ERASE, depending on the function you want to perform.
NB: If you cannot get this function activated with your TV, make sure that the system memory IC on the circuit board of your tV is faulty, and should be replaced with same type and number. Actually it is a very skilled work, and must be done by any well experienced service techinician or by the Authorised Service Center for Toashiba at your town. OK
gopakumarg43
Oct 01, 2011 | Toshiba 32AFX54 TV
Asm after 3 second and then start searching
Hello
ASM [Automatic Search and Memory] function si used for autotuning for laocal and cable RF signals. When each station is tuned in, it will have a particular frequency alongwith a data stream. These data streams are of voltages, and these voltage will store in the memory of the memory IC insde and stored there, and the set will go tuned to the preceding station. This process will continue till all the on-air or cable stations have been stored in different memory locations of the memory IC, and at last the first tuned station will be displayed on the screen.
In your set, this memory IC is now faulty. Replaceing it will solve the problem of your set. This IC can be located very near to the main system control IC, and will have 8 solder terminals. It can be replaced. When replacing it note its number well. This number is very important and should replace it with same number. It is very cheap to buy, and can be bought from most or the electronic spare part shops at your town. OK.
Jul 12, 2011 | Philips 32PT6441/37 32" TV
I need memory ic code for SONY TRINITRON KV-PG21P40
Hello
There is no code for memory IC. It is an 8 terminal IC, in which will have a number printed on it; usually laser printed. Check that number and buy the exact same number. That number is most important. OK.
Jun 19, 2011 | Sony Televison & Video
Ebrom(memory ic) number
try to find the service manual of the tv to locate the ic.these tv,s have the icom ic and the memory in a separate pcb.this pcb is a complete part.you must change all the pcb to solve your problem.the fault ic is the icom not the memory.
May 04, 2010 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Long beep error on startup
try cleaning up the copper terminal of your memory card with a pencil eraser, do it carefully by avoiding contacts with the chips or I.C. carefully swipe the eraser on the copper terminal only and if your sure that it is already clean, carefully wipe the teminal with a soft cloth again avoiding contact with the chips. if the problem occurs again, buy a new memory card.
Sep 22, 2008 | Computers & Internet
Air Conditioner for Benz 1998 E320
Check system for codes;
Displaying & Reading Trouble Codes (DTC Memory)
Air Conditioning (A/C)
Models 208 as of MY 1998
Diagnostic trouble Code Memory [15]
Note:
  • The A/C pushbutton control module (N22) has DTC memory and data output. The diagnostic trouble codes and data are displayed via the temperature display window. The stored DTC's will remain in memory even with the vehicle battery disconnected.
  • The DTC memory differentiates between current and intermittent faults.
  • Numerous DTC's can also be read with the Hand-Held Tester (HHT).
Preparations for DTC Readout
  1. Review 11, 12, 13, 14, 15, 21, 22, 31, 31, 41
  2. Ignition: ON
  3. Temperature selector: left: "HI"; right: "LO"
  4. Ignition: OFF
  5. Ignition: ON
  6. Within 20 seconds press REST and EC simultaneously for more than 5 seconds.
  7. The LED in Recirculated Air flashes and the display shows "d1A".
  8. Press AUTO repeatedly until all DTC's are displayed. Record each DTC as it is displayed.
  9. Each fault (short circuit, open circuit) is assigned a DTC. Thus in the left display: "E1" appears, and the right display indicates the DTC. The current faults (refer to table) are displayed first, next, the intermittant failures (e.g. 45 °5) are displayed in the display window next to the FAN symbol. By pressing the right AUTO the next DTC is displayed.
  10. To erase: Can only be performed after all faults have been readout. Press left AUTO and right AUTO buttons simultaneously for more than 2 seconds and the display shows: left: "d" and right: "FF". To cancel erase: By pressing the left AUTO button, the current faults will appear again.
  11. Select a base temperature setting.
  12. Turn ignition OFF, to end test.
Note: Due to instrument cluster (IC) series interface, DTC's may be stored in IC memory, therefore readout and erase DTC's from IC memory.
133090425133090426
Aug 20, 2008 | 1998 Mercedes-Benz E-Class
Erasing all phone numbers and user information on A650
FROM THE MANUAL
ERASE MEMORY
Erase memory erases your Phonebook and Voice Dial recordings. This feature is useful if you want to give your phone to a friend or family member.
1. In standby mode, press the left soft key (Menu), then press 9 (Setup), 4 (Security). You're prompted to enter the lock code.
2. Enter the lock code (try the last 4 digits of your phone number unless you set a different one), then press 6 for Erase Memory. A confirmation prompt appears in the display.
3. Use the navigation key to highlight Yes or No, then press OK. A confirmation message appears in the display while your messages are being erased. Your phone then returns to the Security menu.
RESET PHONE
Reset Phone returns all setup options to their factory default.
1. In standby mode, press the left soft key (Menu) then press 9 (Setup), 4 (Security). You're prompted to enter your lock code.
2. Enter the lock code, then press 7 for Reset Phone. A prompt appears in the display asking if you wish to restore default settings (except for the Phonebook and Voice Dial).
Feb 05, 2008 | Samsung SCH-a650
Televison & Video Logo
18 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
