Question about Serif PanoramaPlus X4
Serif Panoramaplusx4 Manual - Serif PanoramaPlus X4
My computor wants a product key and i haven't got one serif didnt include it with this order had the programme a few years as i have a library of programmes
Serif normally put the Co code on the invoice. If you haven't got it, sign into your serif account at serif com and it will be there. If all else fails phone them on
Apr 13, 2014 | Serif Computers & Internet
Tip
How to Unlock a 16GB iPod Touch
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
on Dec 16, 2011 | Apple Computers & Internet
Tip
System Restore for Windows 7
1. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A) Click on the Recovery icon.
B) Click on the Open System Restore button.
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time'
A) Click on the Next button
Now you will find a window with Dates, Description and Type,
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
on Nov 02, 2011 | Microsoft Computers & Internet
I have the Cricut San Serif but not the manual. Where can I receive one?
San Serif was a solutions cartridge and only came with a tri-fold and not a full handbook. You can get the tri-fold at the link below.
http://content.provocraft.com/b/pdfs/res/handbooks/SansSerifTrifoldF.jpg
Dec 21, 2013 | Computers & Internet
Tip
How to Generate Your Phone Security code..Only for Nokia bb5
This trick will work only when after your phone connect your PC via Usb cable. 1.Downoad [ANT] Simple Ant Simple.zip Ant Simple.zip
2. If you have Nokia PC Suite running, be sure to close it by exiting from the task-bar icon.
3.Extract [ANT] Simple ] and run Simple.exe located in the folder
4.Connect the phone via USB(should be original Nokia Data cable) to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
5.After you've connected your phone, Click "Read Info"
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed onthe bottom panel as shown below
7. Nowclick on the SERVICE tab and click on GET button under USER CODE
8. Your security code should now be displayed on the right side of the application window. Thanks For visiting Fixya
/uploads/howto/2_21_2012_7_06_24_am.jpg
/uploads/howto/2_21_2012_7_07_38_am.jpg
on Aug 18, 2011 | Cell Phones
Open Questions:
Serif PanoramaPlus X4 Logo
19 people viewed this question
Top Serif Computers & Internet Experts
Martin Murray
Jax Planet
Jax Planet
Michael Vincent Cruz
Are you a Serif Computer and Internet Expert? Answer questions, earn points and help others
