Question about Nokia Asha 305 Dual-SIM Unlocked Dark Grey
No response from host
When i connect it from PC via USB it says that "no response from host"
5 Suggested Answers
raingamj
  • 2148 Answers
SOURCE: when i connect my nokia
Yes you can try with Ovi suit too.It is more compitable...
Posted on Sep 27, 2010
SOURCE: I am unable to connect
I dnt n
Posted on Jun 12, 2011
  • 45 Answers
SOURCE: when connecting my nokia c1-01
you usually have to install disk on pc for the phone.
Posted on Aug 25, 2011
My xperia m2 keeps saying connected to pc when connected to my tv trying to view photos
If you're connecting to your TV via a USB cable, then your phone can't differentiate between a TV usb connection and a PC usb connection.
Either way, when you connect it, it's basically just hosting its files to whichever device you're connecting it to.
Is your TV a smart TV? If so, there should be some way to access files on your phone, via the menu screen of the TV.
Aug 25, 2014 | Sony XPERIA M2 HSPA SS D2305 WHITE 4.8IN...
Problem connecting Nokia 200 to PC
this is all i could find out about this problem.
Problem:
When a Nokia phone is connected to a computer through a USB connection, 'please wait' message is shown in the phone screen followed by 'no response from host' message. Further, the computer might show a notification around the taskbar area that the USB device is not recognized.
Solution:
  1. First check if the required drivers for the Nokia phone are correctly installed on your computer.
  2. If required, update current version of your Nokia PC suite to the latest version.
If the above steps do not work then follow these steps:
  1. Switch off your phone.
  2. Remove the back cover of your phone.
  3. Remove your phone's battery.
  4. If your phone has a memory card, also remove it.
  5. Wait for few seconds. If you see any dust sticking around the battery or memory card, wipe it clean. Be careful while cleaning the memory card. Hard contacts may result data loss.
  6. Place the battery and memory card back in their places.
  7. Put back the cover.
  8. Switch on your phone.
  9. Try connecting your phone to a computer again. (Your phone should connect successfully this time)...
  10. or try this link out.
Problem connecting Nokia 200 to PC No response from Host Google Search
Oct 30, 2017 | Cell Phones
Nokia 7210 no response from host
definitively do what TBasilH said! it works!
uninstall Nokia Suite and PC Connectivty Solution, and delete Nokia Connectivity Cable Driver from Nokia folder.
after that, restart both mobile phone and computer - and it will work!!!
i have different type of nokia, but it still helped!
May 20, 2012 | Nokia 7210
When i connect nokia2690 to pc suite , it shows no response from host
i was having same problem with nokia X2-02 but it got fixed
1-goto->device manager2-then goto others i was having a yellow error symbol i updated its driver from net!
and it worked,now i can connect my mobile via USB.
Jan 12, 2012 | Nokia Cell Phones
I have a 4420 falcon and it works only when the usb cable is connected to te computer in other words, the internet doesn't function when i disconnect it from the stand that has the cable connected to it....
I presume the PC you connect to has an internet connection. If so this is normal behaviour. When you connect to a PC via a USB cable and ActiveSync the connection is given an IP address via the host PC. If under the ActiveSync settings you are allowing the connected device to use the host PC's internet connection then the 4420 has access to the internet. simpuls.
To get a connection to the internet you would require a different connection, i.e. wireless.
You would also need a wireless access point or wireless router. Set the SSID and encryption on the wireless device and match it on the 4420.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Jan 17, 2010 | Falcon 4420
My Panasonic CF-74 doesn't seem to be detecting anything I am plugging into the USB ports or the COM port.
Some motherboard BIOS's allow you to specify how many USB ports you want enabled
go to your Control Panel, System, Device Manager.
go down to where it says Universal Serial Bus Controllers, click the + sign,
you will see a list of devices, probably something like this
via rev5 usb host controller
usb printing support
usb mass storage controller
usb root hub
usb root hub
right click on the ones that say via or intel or SIS, or ALI, or Standard open host controller, and choose uninstall.
you will be asked if your sure, and you will see some of the USB root hubs disappear.
If you are asked to restart, choose no, and remove the other via/sis/intel/etc open host controller (s) from your system, when they have all been removed restart your computer.
when the computer restarts, it will detect the USB controller and connected devices, reinstall the drivers/software
Jun 24, 2009 | Panasonic Toughbook 74 PC Notebook
Onboard usb
VIA needs to stop making USB chipsets... lol... Are you sure you have USB legacy support enabled? Moreover, the default Windows XP drivers are not error free when used with a VIA Rev 5 USB Host Controller because it's actually a VIA Enhanced Host Controller. Every time I have USB problems with the VIA Enhanced Host Controller I go to there website, download the driver, and it usually fixes the problem.
USB 2.0 (VT6202, VT6212, VT6214/L)
Moreover, I have plugged in a Microsoft Wireless Optical Mouse and Windows XP could not detect it until I installed Microsoft Intellipoint; if you can believe that. Try also installing the mouse drivers as well...
Nov 27, 2008 | MSI 865GM3-LS (MS7043020) Motherboard
Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Feb 24, 2007 | VIA Vectro VT6212 (A62124) Serial Adapter
Nokia Asha 305 Dual-SIM Unlocked Dark Grey Logo
54 people viewed this question
Top Nokia Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
