Question about Quasar VHQ940 VHS VCR
VCR Stops on me
I put the tape in the VCR,I push play,in 3 seconds it will either stop playing or  the power will shut off. No matter how many times I try to start playing the tape,it does the same thing over and over.
    Genius:
  • 1,139 Answers
Hello Ro Power,
This might be due to the tape sensor malfunctioning. You will need a schematic, and multimeter, and a LED power meter to work on this problem. When the tape loads it causes an LED sensor to become blocked and then the sensor tells the control chip that a tape is present and the the controll chip allows the tape to continue playing, if the sensor does not work the signal never gets to the control chips and since other events happend and triggered the control chip the control chip looks at this as an error and the stops the tape , some units even eject the tape.
If you do not have a background in electronics, I would suggest that you take the VCR to a qualified shop and have them repair it.
I hope this helps,
Thank You,
Shuttle83
Posted on Oct 18, 2007
My zenith 4head vcr works, then stops
When a VCR encounters a mechanical problem, the electronics will stop playback and shut it down. I suspect that fault has developed in the mechanism and that the tape becomes jammed. The only way to find out it to take off the top cover and watch what happens when the video tape is played.
Dec 28, 2013 | Televison & Video
The VCR accepts the tape and starts to play; then stops and shuts off; when you turn the power back on the tape ejects
You have a transport problem, the mechanism the plays, FF or rewinds is not working.
Someone is going to have to open and look at the unit---as simple as a belt off or broken to the idler (rubber or geared) that doe the actual work, finding a shop that will work on a VCR unit is getting hard as most of the current techs have never seen this type of unit.
What I used to do when I opened one was have a old cassette with the tape removed! but the reels inside of it still there--tape off both sides of the cassette where it opens so the sensors on either side do not try to stop the unit from allowing this.
This way with the unit open and the dummy cassette in you can see thru its top to see if the reels are moving or not and not have the tape get in the way.
Dec 06, 2012 | Magnavox DV220MW9 DVD Player VCR
Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Feb 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
Magnavox VCR/DVD player CMWR 20V6
The same thing happened to me and it is the power supply. You can get a new one at parts@funaiservice.com
Nov 26, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My vcr won't play.
Sounds like a bad belt or the tape isnt loading into case correcly bad rubber idler assy.
Oct 23, 2008 | Quasar VHQ400 VHS VCR
Shuts down after 8 seconds of play.
Does the tape hang out when you eject the cassette?
8 seconds is about the time that the VCR brain allows the mechanism to run when there is a problem before shuting down. Just guessing from the model number, but I'd say the unit needs a belt job.
Dec 24, 2007 | Televison & Video
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Televison & Video Logo
250 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
