Question about HP OmniBook XE2 Notebook
Mouse will only work if directly placed in the usb port
On the laptop. will not work with the hub. I do get power to the hub, but it is like the laptop will not recognize an external usb hub. Thumb drive will not work in either the hub or the port.
    Sniper:
  • 52 Answers
This is really strange
i have buy a hub on chinese store and the computer recognize only the mouse, not the hub, but it works
try to install the driver if the mouse have anyone. and try to install the driver of the hub
Posted on May 18, 2009
I have sahara n1356 laptop which freezes mouse and keyboard when i start it. what could be a problem
Try following tips:
Try to connect your keyboard and mouse directly to your laptop's USB ports (instead of using the USB hub) and see if they still freeze.
OR
It sounds like you're using an unpowered hub, which in my experience tends to cause most common errors with USB peripherals. It's definitely not recommended to connect any USB devices which aren't supplied with a power adapter (for instance some 2.5" external HDs and those small photo printers). These sort of devices should be connected directly to your laptop at all times.
You could also consider buying a powered hub, i.e. an USB hub which draws its power from a separate power adapter (and not your single laptop USB port).
if it doesn't work you can try this..
Click Start, and type device manager in the Start Search box.
Click Device Manager in the Programs list.
If you are prompted for an administrator password or confirmation, type your password or click Continue.
In the Device Manager dialog box, expand Universal Serial Bus controllers.
Right-click USB Root Hub and then click Properties.
In the USB Root Hub Properties dialog box, click the Power Management tab.
Remove the check from the Allow the computer to turn off this device to save power check box. Repeat steps 1 through 4 for each USB Root Hub listed in the Device Manager.
Under Power settings, check the 'USB settings' -> 'USB selective suspend settings' and make sure it is disabled.
Check Thumbnail, highlighted: Open Device manager, Double click on Universal Serial Bus controller at the bottom, Double Click USB Root Hub, Click Power Management on top right, Uncheck Allow Power...
Hope it works for you.
Sep 20, 2011 | Dell Dimension 8300 PC Desktop
Laptop Model : Dell XPS 1530 i think i m having some problems with the usb power issue. Problem 1: when i connect an external hard drive which have bigger capacity than 120gb, the power of the usb will...
It sounds like the motherboard is causing the usb ports to malfunction by allowing power surges into the power input to the ports.You maybe should try a powered usb hub to power your hardware or you may face motherboard replacement
Jan 10, 2011 | Dell XPS M1530 Laptop
My both usb ports r not wrking n hangs when eithr card reader or pen drive is inserted bt works well when tata photon usb port or mouse port or key board port is inserted ?model- EMACHINES E275
Sounds like your laptop's USB ports are not capable of providing enough power to operate your card reader or pen drive. I suggest you buy an active USB hub (one with external power source, rather than the one which draws power from the laptop's USB port), & attach your card reader and/or pen drive to that USB hub.
Nov 28, 2010 | Acer Computers & Internet
How do i connect my wireless i.t.works optical mouse model MWO03 to my eee laptop windows 7?
Follow these steps :
1.
Check to see if your laptop supports wireless technology (Bluetooth, 802.11 or other). If it doesn't, you will need a wireless receiver. If it does, verify that your laptop is compatible with your wireless mouse, which could use either Bluetooth technology or a radio signal.
2.
Unpack your mouse and open its battery compartment. The wireless mouse won't receive any power from the laptop, making batteries necessary.
3.
Add new batteries to the compartment. Make sure that the + battery end is inserted into the + niche in the compartment.
4.
Place the mouse where it is easy to use and least stressful on your fingers.
5.
Place your wireless receiver appropriately if your laptop doesn't support wireless technology. The receiver should be kept at least 8 inches away from the laptop or any other object that would cause any interference.
6.
Place the wireless receiver anywhere from 8 inches to 6 feet from the mouse.
7.
Insert the driver CD into your laptop and follow the instructions to install the software for running the mouse.
8.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop. If you do not have a free USB port, simply use an external USB hub for more ports.
Nov 07, 2010 | Computers & Internet
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
Why does my iOmega LPHD-UP USB external HD not work with 7-Port USB hub? Is it the 500mV limitation per port or something else? Works fine if plugged directly into the laptops only USB port.
you got it! may need to get a 'powered' usb hub. another 'wall wart!', but will probably allow use of hub to power usb hdd!
good luck!
Oct 11, 2009 | Computers & Internet
When i plug my usb mouse or the webcam on my new motherboard my PC does not open,.while the ps2 mouse it works,.moments ago i restart the PC and it has a message POWER SURGE ON HUB PORT!!.HOW can i solve...
you are connecting your mous mous or web cam through a usb hub which is not having power to run the device instead you should attach a device directly to the system or use a hi speed usb 2.0 hub
Sep 16, 2009 | XFX GeForce 6200 Graphic Card
When I plus my small HP camera into the hub port, I get a message that the hub doesn't have sufficient power to run it. I only have the mouse and keyboard plugged into the hub.
If you have an option to turn off USB charging for the camera try this and see if it will work then assuming that all you really want to do is transfer files. If not, then you'll need to switch the camera to a direct USB port on the computer or buy a powered USB hub.
Jul 18, 2009 | Belkin (F5U237) 7-Port USB Hub
Xb 3000 usb connections
I to have experienced the same problems with my xb3000 and as soon as i uninstalled the usb's and did a reboot it worked fine. Got me up and running.
Mar 02, 2008 | HP Xb3000 Notebook Expansion Base And...
HP OmniBook XE2 Notebook Logo
135 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
