Question about Brother LS 2160 Sewing Machine
Replace bulb - Brother LS 2160 Sewing Machine
Quantum cxl. Why doesn't replacement lamp work?
Or it could be the incorrect bulb for the machine or if purchased from a secondary market, ie China, etc. I've purchased a replacement bulb from eBay and even though it was guaranteed to work in the machine, there is a lip on the bulb that prevents it from being inserted completely into the machine. Might be best to purchase an authentic replacement bulb from a dealer.
Feb 22, 2016 | Singer Sewing Machines
How do you change bulb on singer curvy 8763? Nothing in manual, nothing online. Can it be replaced? Seems to be soldered in or something and no replacement listed either.
The Singer Curvy 8763 bulbs are LED bulbs so they should last for 100,000 hours (or probably the life of the sewing machine). Thus the bulbs aren't meant to be user replaceable. Unfortunately, even though the bulbs should last for years, Singer only provides a one year warranty on them. Thus if your machine doesn't have working lights and isn't still in that first year, you'll have to pay for the repair.
I hope this helps and wish I had better news for you if there is a problem with the lighting of your sewing machine.
Nov 16, 2015 | Singer Sewing Machines
I have a 6212C Singer sewing machine and I removed the plate that holds the bulb in place and somehow cannot replace it properly to where the face fits on.
Download your user manual free from Singer and go to Page 66. You might find it useful. Another question -- is the new bulb exactly the same size as the old bulb?
Sep 30, 2015 | Singer Sewing Machines
Can I replace an ordinary light bulb in my Janome machines with a LED bulb?
as far as bulbs they will work fine IF you ever find the proper ones, size wise .
May 05, 2015 | Janome Sewing Machines
How do I replace light bulbs in a Bernina sewing machine model 1080?
Check the bulb model number old versus new and make sure you have the same number bulb. The bulb number should be on the base of the bulb somewhere. If the bulb has tabs sticking out of the base, check to see that they are placed such that both tabs are on the same plane on the bulb base. Some bulbs have offset tabs that only go in one way to the socket. Try rotating the bulb 180 degrees and insert it again to the socket before trying to rotate it. Check your manual for bulb replacement procedure. Make sure also that you didn't rotate the glass bulb out of its base when you pulled the old one out, leaving the old base still stuck in the bulb socket. If this is the case, unplug the machine and use needle-nose pliers to remove the old bulb base before trying to replace the bulb.
Jan 14, 2015 | Bernina Sewing Machines
How do I replace the light bulb on a Singer sewing machine Athena model 2009 ?
I'm not familiar with this model, but in some machines, the bulb is in a socket underneath the arch. On some machines, you open the side door above the needle mechanism and the bulb is in there.
If you can reach the bulb, depending on the machine, some have a small screw in lamp, just like a regular light bulb, But others use push in bulbs. Typically you remove it by pushing in gently, and turning it as you do so, so it pops out. If one way isn't working, turn the other way. Replace the same way, turning in the other direction.
Nov 19, 2014 | Singer Sewing Machines
How do I Replace light bulb in bernina 1010
Theres a gray flexible cap about 1.5" long and .75" in diameter that comes with the machine. It is used as a tool to screw and unscrew the bulb. Weirdly I have had my machine since I bought it new in about 1987 and have never replaced the bulb. And I do use it, at times heavily.
Aug 17, 2012 | Bernina Sewing Machines
Replacement bulb for a Necchi 537FA
it's the same size as a night light bulb. That's how I replaced mine. You can pick one up at any hardware or dept store.
Oct 31, 2009 | Necchi 3537 Mechanical Sewing Machine
How to replace light bulb at Pfaff Creative 2124?
On these machines you cannot open the left side to remove the bulb. Your machine accessory kit should have come with a rubber tool that is ribbed with a cup-shaped opening on either end. This is a tool for removing the bulb. Tilt the machine with the base facing up so you can see where the bulb is and use this tool to twist the bulb gently. It sould come out with no problem! Hope this helps!
Sep 11, 2009 | PfaFF Creative 7570
Bulb is fused
There is no problem if the bulb was busted,just dismatle it replace a new one.Open face cover plate where the bulb was socket.turn bulb in left drection from the socket to pull out.Be sure the power was off no power supply). replaced a new one.
Feb 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother LS 2160 Sewing Machine Logo
20 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
