Question about LG WT5070CW 4.7 Cu. Ft. Ultra Large Capacity High Efficiency Top Load
LG WT5070CW washer leaked in front of machine
  • 38 Answers
SOURCE: LG Top Load Washer
this could be a drain hose loose or broken if the leak only occurs during rinse. If it leaks all the time, could be a broken outer drum or worn tub seal.
Hold inner drum and turn bothways. If it turns bothways, you have a bad bearing, and hence, a bad tub seal. If it turns in one direction only, bearing's good; but tub seal could still be bad.
Posted on Jul 23, 2008
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 23 Answers
SOURCE: My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Posted on Sep 14, 2009
  • 66 Answers
SOURCE: I have an LG WM2277HW front load washer that is
check ur inlet hoses on the outside of machine, also check the connections inside the panel in back
Posted on May 08, 2010
rickead1
  • 1998 Answers
SOURCE: LG Front load washer wm1832cw
hello this is the entire schematic for your machine click here http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Washer-Parts/Model-WM1832CW/3204/0153200?pathTaken=&prst=0&shdMod=WM1832CW if you remove that rear access panel locate on this diagram as part number 101 http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0810334-00001.png and run the machine on the gentle cycle you should be able to determine where your leak is either the pump or the drain lines or the boot that goes into the tub i have seen so many differnt types of foriegn debris stuck in this lower boot paper clips, bra wires, pens etc these sometimes cause a puncture in this lower boot also part numbers f315 k 520 which are both bellows should also be checked for any leaks as well as the drain pump which is located at k344 if you have any further questions message me back i will be in flight from tuesday evening until thursday morning finally leaving hawaii to go back to east coast Thanking god on that note I await your reply Thanks Rick
p.s this is the last link that shows where these drain pieces are http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0810334-00002.png
Posted on Mar 29, 2011
Why do all loads in our Top Load HE Washing Machine - Model # WT5070CW - stop because of UNBALANCED LOAD ERROR?
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
Feb 26, 2015 | LG WT5070CW White Top-Loading Washer
Fix LE error for LG washer
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
Oct 07, 2014 | LG WT5070CW 4.7 Cu. Ft. Ultra Large...
Drain hose
You may be able to get a longer hose from LG. You also could fabricate a longer hose from a length of stock, the U-shaped fitting, and a hose clamp. Another way to lengthen the hose is to cut it at mid length, insert a piece of plastic pipe and secure with two hose clamps. I am using this latter method currently and it works fine
Apr 12, 2013 | LG WT5070CW Front Load Tumble
Lg waveforce wont drain
New drain pump may be needed
Oct 07, 2017 | LG Wave Series WT5070CW
Washer does not add enough hot water
He is right, we can thank the energy mandate for than. In all new washers they are only required to reach 69 degree. All detergent are now activated at 62 degree no matter what. Some washers do get hotter but not lg
Dec 06, 2012 | LG WT5070CW 4.7 Cu. Ft. Ultra Large...
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
LG WT5070CW 4.7 Cu. Ft. Ultra Large Capacity High Efficiency Top Load Logo
46 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
