Question about Baby Lock Ellure
My needle wont thread!
When I push the lever down on the left, the thing will come down but it wont push the part towards the needle, at all. It was trying to do it, now it wont at all. What do I need to do. I've tried oiling the bottom part. But it didn't seem to help.
  • 1,263 Answers
Hi, i need the make and model please ?
Regards
www.electronicrepairs.co
Posted on Dec 28, 2013
4 Suggested Answers
  • 14 Answers
SOURCE: on a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Posted on Jul 07, 2009
SOURCE: when I try to thread the right looper, I cant get
Hi, I have a Babylock Imagine, but had exactly the same problem so found your question when looking around. After tinkering for a bit, I figured out that there was a thread stuck somewhere between the air threading hole and the lower looper eye, and it was causing the air to blow backwards. I pulled the thread out and everything started working correctly. Looks like the Evolve is set up similarly--pull down the front cover, then pull the needle cover down and see if you see anything caught in there.
Posted on Aug 12, 2009
  • 1564 Answers
SOURCE: thread continues to tangle on Ellure Plus even after changing out needle, bobbin, etc. Noticed that a small 'bar' was across front of feed dogs-pushed this back to the left but problem contin
Your post made me laugh with the funny bone remark. :) I'm glad you found and posted a solution to your own problem. Bravo!
Happy sewing.
Posted on Sep 17, 2012
Thread this machine?
What is the make and model of the machine?
Jan 26, 2015 | Sewing Machines
How to thread the machine
From the spool pin take the thread to the left and over the top cotton guide, bring the thread towards you and straight down in between the tension discs, make sure the presser foot is up so the discs are open, straight down towards the needle and round the first big cotton guide, straight back up to the take up lever making sure the take up lever is at the top, right to left through the eye of the take up lever, straight down to the needle going through any guides on the way, thread the needle front to back
Oct 02, 2013 | Necchi 4575 Mechanical Sewing Machine
How to thread 4575
From the reel on top, thread goes to the left and over the back guide and then to the front, straight down through the tension disc make sure the presser foot is up so the discs are open,round the first guide and back up to the takeup lever making sure thge lever is at the top, through the takeup lever right to left, straight down towards the needle taking in any cotton guides on the way and thread the needle front to back
How do you thread the machine
With the machine off, lift the presser foot and raise the needle to the highest position with the hand wheel. Put your spool of thread on the pin and pull the thread through the thread guide on the top rear of the machine. The thread goes under and then over the guide heading down towards the tension disc. Bring the thread down on the right side of the disc and up on the left (left being closer to the needle). Hold onto the thread on both sides of the tension disc and pull the thread up to seat it in the disc. Continue pulling the thread up in the left channel and up to the take up lever. Get the thread up over the back of the take up lever so that it goes into the slot of the lever. Bring the thread down to the guide above the needle and then thread the needle. Leave a few inches of thread behind the needle. Make sure that the needle is correctly positioned in the needle holder.
For pictures of threading the XL-2610, see http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faqh/000000/000400/000067/faqh000467_000.html?reg=us&lang=en&c=us&prod=hf_xl2600i2610eus&page=FaqEndPage .
The full manual is available here: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000200/xl2600ug01enes.pdf .
I hope this helps.
Aug 08, 2012 | Brother XL-2610
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
How to guide thread on kenmore 158.13201
Most machines are very, very similar, therefore, no matter what brand you own, there's basically the same steps to follow: 1. Place good quality thread on spool pin, back right-hand side of machine and raise presser foot UP. 2.Pull thread taut from spool.Make sure silver take-up lever raised to highest position. 3. Guide thread under first tension disc. 4. Hold thread taut, guiding thread into next tension disc. When you get to the take-up leaver (silver lever on right side of machine that has a hole at the top--hold thread taut guiding it from right to left through hole, bring thread down left side of it, and put thread into tension bracket, hold thread taut! Put thread in back of needle into another small bracket and pull thread towards you. Time to thread needle: put thread front to back into eye of needle. Put thread under presser foot and pull under the center of it a good 6".Lower presser foot on scrap of fabric to test. Turn hand wheel toward you to lower needle into fabric scrap. Use foot (or knee depending on machine) to start machine. Do not pull or push fabric but gently guide it. Jimmy Place fabric scrap under needle. Low
Apr 04, 2012 | Kenmore Sewing Machines
How do you put the thread for the needle for a singer sewing machine model 132q?
Put spool of good quality thread on the spool pin. Thread comes off spool counterclockwise. Raise your presser foot before you do the next steps: Presser foot lifted up now? Great! Pull thread tail from spool toward you and hold thread taut as you put it into first tension disk. Have that thread nice and taut? We shouldn't have any loops hanging down over the machine--okay, Keep threading all of the tension disks. You should be able to actually "feel" the thread fall into slots somewhat. Now when you get to that long silver thing with the hole in the top this is called your thread take-up lever. It should be all the way UP. Turn hand wheel- ( large round knob at end of right-hand side of machine) towards you if need be to raise it. Pull that thread taut from RIGHT to LEFT through the hole in the take-up lever. Take deep breadth here... You're almost done! Pull thread down left side of lever til you get to next disk. Put thread in small bracket located behind needle. Bring thread forward --get yourself 6" of thread-- then put it from front to the back of the eye of the needle. Are you okay? Hope I was able to help. Jimmy
Mar 31, 2012 | Singer Featherweight 132Q Mechanical...
How do I thread this machine
Threading the Machine
Raise the thread take-up lever to the highest point by turning the balance wheel towards you. (Large round wheel on your right of the machine.)
Raise presser foot with presser foot lifter and pass the thread in the order from
[1] to [8]
[1] Pass the thread through the top cover thread guide.
[2] Draw the thread around the thread guide and down into the tension.
[3] Then down around the check spring holder.
[4] Firmly draw the thread from left to right over the take-up lever and down into the take-up lever eye.
[5][6] Then down through the lower thread guides.
[7] Slide the thread behind the needle bar thread guide on the left.
[8] Thread the needle from front to back.
Sep 06, 2010 | New Home L-372 Mechanical Sewing Machine
How to thread the machine.
http://www.instructables.com/id/How-to-Thread-a-Sewing-Machine/
check out this link.. it is described clearly with the help of images...
OR
try to do by reading these steps..
Step 1 Raise the needle to its highest position by turning the handwheel toward you.
Step 2 Raise the presser foot. This will allow the thread to easily pass through the threading points and will prevent the machine needle from becoming unthreaded when you begin to stitch.
Step 3 Place a spool of thread on the spool pin located at the top of your sewing machine. If the spool pin runs horizontally, secure the spool of thread with the cap provided.
Step 4 Take hold of the thread end and pass it through the designated threading points on the top of the machine casing, then down toward the tension assembly. The tension assembly is located on the left side of the machine and controls the flow of thread.
Step 5 Take the thread under the tension assembly and back up through the next threading point at the top left of the machine. Make sure the thread has passed between two tension discs as well as the hook that may be attached to the left side of the tension dial.
Step 6 Push the thread end through the lever at the top left of the machine, if applicable, and down through the threading points at bottom left and above the needle.
Step 7 Thread the needle from the front or back of the needle. The threading direction will depend on your machine type.
Step 8 Pull a few inches of thread through the eye of the needle and pull the thread to your left.
Step 9 Insert a wound bobbin into the machine, if necessary, and close the throat plate. A few inches of bobbin thread should be pulled out to the right and sticking out from under the closed throat plate.
Step 10 Take hold of the thread that has been threaded through the machine needle.
Step 11 Rotate the hand wheel toward you until the needle disappears into the bobbin case.
Step 12 Keep holding on to the thread and move the hand wheel so the needle is once again at its highest position. As the needle rises, a loop of bobbin thread will come up as well.
Step 13 Pull the thread out toward your left to draw the bobbin thread loop further out of the bobbin case.
Step 14
Let the top thread go and pull the bobbin thread up until the end comes up. Pull the top and bottom threads under the presser foot and to the back and right of the machine.
please rate this solution...
gkgb.
Jan 13, 2010 | Sewing Machines
How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Dec 10, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Sewing Machines Logo
24 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
