Question about JET Performance 1999 Pontiac Grand Am Mass Air Flow Sensor
What causes the check engine light to stay on in a pontiac grand am se
Check engine light, trac light , and a battery light, i have fixed knock sensor, oxygen sensor, and timing chain, and other things, what else can i do? please help
    Sergeant:
  • 302 Answers
Maybe get a techy to get into reset computer to tell it these things have been done. When ever I replace brake pads have to reset computer because it says ABS, Trac is outa wack when they are not
Posted on Dec 29, 2013
2 Suggested Answers
  • 73 Answers
SOURCE: check engine light stays how to get it out
You must clear the code . It can be cleared with an OBD2 code reader and some vehicles will clear by leaving the battery cable off for a while.
Posted on Dec 28, 2013
Check engine light stays how to get it out
Dec 28, 2013 | JET Performance 1999 Pontiac Grand Am Mass...
Service eng light,abs light,trac control light all stay on
sounds like possibly one of the sensor connections is disconnected possibly when oil was changed maybe one of the plug ins were knocked off or partailly disconnected, check all plug ins under hood most likely a plug in on the abs unit under the hood,(usually has lines running to the master cylinder) possbly plug in onthe master cylinder also.
Sep 12, 2012 | 2003 Pontiac Grand Prix
2001 grand am se jerking when changin gears trac off light on
Final drive speed sensor causing Trac light and rough shifting. Metal dust on the sensor. Have the transmission filter and fluid serviced. This should have been done at 60,000 miles. You may get an ABS light too. Service the sensor. Perform an OBDII scan for stored faults.
May 20, 2017 | 2001 Pontiac Grand Am SE
Abs light ,trac off, and service engine soon would come once in awhile, but now its on all the time. my turn signals sometimes won't work either.
These are differnt issues. The Trac off light is on because the ABS is on most common reason is because of a bad abs sensor which is part of the wheel bearing unless there is any damaged wiring.Your check engine light is on for another reason there could be many possibilities.The turn signals may be the hazard switch or turn signal switch. You should take to a repair facility that has a scan tool to tell you what are causing the abs and engine lights to come on.
May 15, 2010 | 2001 Pontiac Grand Am SE
Abs light, trac light, service engine soon light 2001 Pontiac Grand Am
Sounds like you have a bad wheel speed sensor. You need to have it scanned. Since it's been sitting, it might just be a bad connection to one of the speed sensors.
Jun 01, 2009 | 2000 Pontiac Grand Am GT
Engine hesitation, the trac off light comes and car hesitates.
ABS sensor on wheel hub bearing. I had the same problem cange it and problems went away
Jan 26, 2009 | 2001 Pontiac Grand Am SE
Pontiac grand am Gt 2000 v6
i had the same problems. replacing the wheel bearings and front hubs fixed it
Oct 21, 2008 | 2001 Pontiac Grand Am SE
Pontiac 2002 se: veh soon light, trac light, abs light comes on
I have this same problem and had it checked. It is the wheel sensor. Mine is the passenger front right wheel sensor. According to the mechanic I take it to the GrandAm's are known for this. The part is about $40.
Oct 07, 2008 | 2002 Pontiac Grand Am
2000 Grand Am SE trac off
It is possible that you pushed the ETS button. The 'trac off' light comes on in my Grand Am when this is pushed.
Aug 03, 2008 | 2000 Pontiac Grand Am GT
JET Performance 1999 Pontiac Grand Am Mass Air Flow Sensor Logo
71 people viewed this question
Top JET Performance Computers & Internet Experts
David Payne
David Payne
Are you a JET Performance Computer and Internet Expert? Answer questions, earn points and help others
