Question about Wowwee Mini Robosapien Humanoid Robot
Will not walk? - Wowwee Mini Robosapien Humanoid Robot
Belt is skipping
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jun 13, 2010 | Proform 325 Treadmill Walking Belt
Belt is slipping when i walk on it
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 17, 2010 | Icon Image 17.5 S Treadmill
Wowwee Mini Robosapien Humanoid Robot Logo
Top Wowwee Toys Experts
Michael Vincent Cruz
Shekar Avadhani
Tom Chichester
Are you a Wowwee Toy Expert? Answer questions, earn points and help others
