Question about Mitsubishi WT-46807 46" Rear Projection Television
Mitsubishi HD 65" thin squiggly line in upper right corner that moves
Tv is 5 years old
noticed this after it was moved to new house
line is very thin, vertical, squiggly
it moves, wiggles back and forth
only can see it when the color in the upper right is light
not very noticable at all
thank u very much for any help
  • dukey26 Oct 28, 2007
    thank u very much for your help
    the squiggly line is there on every channel and every source unfortunately
    it kinda looks like a peice of string dangling back and forth in the wind if that makes sense
  • dukey26 Nov 06, 2007
    Thank u very much. That solved my problem. Now i did want to see if there was anymore cleaning i should do inside. Also when should i replace bulbs. Anything else i should do since it is 5 yrs old? Once again, thank you very much.
  • 1,694 Answers
Is the problem there on every source? DVD playback ok?
Suspect signal source  box.
May have bad connection since move.
Is the problem same on every channel,if source is cable direct?
Please provide more info if more help needed....T.
Posted on Oct 22, 2007
  • Vista Electronics Oct 29, 2007
    How about cleaning inside the rear projection cavity??
    If a spider web gets between the lens and the back of the
    screen-------two ways to clean a Mits---
    1) Remove bottom,rear cover---reach up inside with duster on
    extension pole and knock down spider webs.When finished,
    wipe clean RGB lens caps with soft cloth.
    2) Remove speaker grill cover in front,then remove hidden screws
        holding screen assembly,lift up/out.
        Clean out cobwebs and clean lens caps,reassemble.
I have a barely I year old Samsung UHD Tv 65" 9000 series and last night while watching basketball, I noticed a very thin green verticsl line about 4-5" from the right edge of the tv on the screen. Wh
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 11, 2015 | Samsung Televison & Video
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My PS3 connects to my 3yr old Mitsubishi HD tv fine via HDMI or the analog connection. However, using the same cable(s) it won't do anything but flash a squiggly green line a couple of times on a 6 year...
yup one or the other is capped at or below 1080 P - I so when you go to power it up at a new tv push and hold power till it makes the second beep 5 secs later and your good to go ok :)
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
Thin white horizontal lines!!! I've had my WEGA KE-42M1 for 5 years with no problems until about three months ago. After about an hour being on, there are thin white horizontal lines that move randomly...
Sounds like your TV is giving out, plain and simple.
If this doesn't sound right, then only one thing comes to mind. Have you moved the TV recently? Are you using a different coax cable, (if using cable that is). If so, just change the cable back to the previous one and you should be fine.
Aug 21, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Hi kmb0516.
Depends how old the set is, if it is more than 5 years old, time to tell it goodbye, if it is less, might be worth fixing.
I believe the problem is in the vertical output section, it sounds like the picture has shrunk.
Hope this helps, Greg.
Aug 13, 2008 | Sylvania SRT2232S 32" TV
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hello hope. Try pushing in the input and menu buttons on the set and hold them both in together for 8 seconds to see if the Led will blink a two digit code then let me know what that code says. I can get you a link where to get a new power supply, but that may not be your problem. Try this test an see what the led blinks if anything then let me know I will try to help you determine whats wrong. I am a specialist with mitsubishi projection units.
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Nov 05, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Hitachi 53sbx10b
Try the auto convergence feature of the TV. Press the button on the front of the tv and wait about 5 minutes....
Apr 27, 2007 | Hitachi 53SBX01B 53" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
158 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
