Question about Uniden BC370CRS Base Scanner
Scanner won't run through the channels
Says scan and stuck on one channel
SOURCE: SVC Scanning
Reset scanner by powering off, press the Hold,2 and 9 keys all at the same time and turn on the scanner.
Posted on Jan 01, 2009
  • 120 Answers
SOURCE: scanner wont scan
provided you turned the squelch know and it didnt help, i would trace back from the squelch control to the first and second transistor you come to and that should be the squelch circuit. if you know how to check them with an ohm meter you can find out which one it is, if not you can just replace them both for under 5 bucks.
Posted on Jan 10, 2009
SOURCE: acts like squelch is stuck
I had the same problem. Your board may be fried. I had to buy a new unit.
Posted on Jan 28, 2009
BillB-SA
  • 2761 Answers
SOURCE: manual for Bearcat Scanner BC 140 10 channel
I couldn't locate a manual for your oldie, but it's fairly simple to operate.
  1. Turn the scanner ON.
  2. Press "Manual" to stop scanning. Use the keyboard to choose the channel you want to enter your first frequency into. If you want channel 2, press the number 2 on the keyboard and then "Manual" again. If you want channel 12, press the 1 and then the 2 and then "Manual" again.
  3. Enter the desired frequency, including the decimal point. For instance, if the frequency is 555.789, enter 5, 5, 5 and then the dot button, then 7, 8 and 9. Then press "Enter" to complete the setup.
  4. Use the "Manual" button to move to the next channel to enter the next frequency. Continue this process until you have all frequencies entered.
  5. Complete your entries and then press "Scan." Set the squelch by turning the "Squelch" knob all the way up and backing off until you hear no static.
  6. Lock out a channel that is annoying you by pressing the "Lockout" button. If you want to listen to the channel again, simply select "Manual," find the channel by entering it on the keypad and then hit "Lockout" again
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Posted on Dec 12, 2009
BillB-SA
  • 2761 Answers
SOURCE: how do you set up the scanner to scan police and
First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
Once you've selected your frequencies, power the scanner ON and
1. Press E/PGM to enter the program mode (the scanner turns on the
PGM icon).
2. If the current channel is not the one you want to program, enter the
memory number then press HOLD.
3. Enter the frequency including the decimal point, then press E/PGM.
4. To program the next memory, press  or  and repeat step 3. To
program a different memory, repeat from step 2.
5. To exit program mode, press HOLD or SCAN or change the scanner’s mode.
Notes:
• Any frequency you program replaces the previous memory contents.
• If you enter a frequency you have already stored in a different
memory in Step 3, the scanner beeps and displays the channel
where you have previously stored the frequency. If you want to store
the frequency anyway, press E/PGM a second time in Step 3.
• To clear the contents of a memory, enter “0” in Step 3.
• Channels you program are automatically unlocked (see
“Locking/Unlocking Memories) and have Delay turned on (See
“Setting Channel Delay”).
If you would like to download/print the operating manual for you scanner, visit:
http://uniden.com/pdf/BC340CRSom.pdf
BillB
Posted on Jan 12, 2010
What does it mean when a channel is "locked out"?
That is a setting that is used for channels that are constantly broadcasting but you don't want to scan them because they will stop the scanner. An example is the noaa weather channel. You may want to have it on the scanner as a channel but you don't want to scan it because the scanner will stop on it all the time.
Feb 25, 2015 | Uniden Bearcat 560xlt 560 Xlt 16ch Police...
SCANNER PRO 97 WAS TRYING TO PROGRAM AND NOM WHEN I HIT SCAN IT SHOWS AII CHANNELS LOCKED OUT.
You may have a priority channel selected if it refuses to scan.i believe most scanners will reset if you remove batteries for a period.some cellular channels are blocked in the USA so if it's not a cellular frequency and you are not in a country with restrictions then you really need to understand how to input a frequency ....store it... Remember to adjust squelch as the squelch when turned fully on will not usually output any sound and lock scan if it's turned off in most cases.
Feb 05, 2015 | Radio Communications
Scanner stuck on one channel and won't allow me to enter new freq
Push the "L/O" lockout button and it will lockout that channel.
When you press "Scan" you have to have at least one of the banks scanning, so press 1, 2, 3,....9, 0 whatever bank you have channels programmed in order to automatically scan. You should be able to press "Manual" to see each channel individually.
May 07, 2014 | Uniden Bearcat BC 220XLT Radio Scanner
Stuck in lockout mode
radio shack pro 97 scanning receiver,
Jul 17, 2012 | Uniden BC60XLT-1 Handheld Scanner
Bc898t all 500 channels are locked out. How to unlock all of them
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again.
Mar 29, 2011 | Uniden BC898T Base Scanner
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
Radio Shack (Realistic) PRO-2020 Scanner stuck in Scan Mode
Sounds like old age - the 2020 is nearly 30 years old! Have you tried just using the LOCKOUT feature on all channels except the you want? How about just programming the same frequency into all 20 channels?
Jul 25, 2009 | Aiwa AV-S17 Receiver
Uniden BC370CRS Base Scanner Logo
70 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
