Question about NetGear USB 2.0-Stick WiFi 108 Mb WG111T (80229) 802.11g/b Wireless Adapter
Re set wireless usb adapter
I had to re-install my Netgear WG111t wireless usb adapter and now it will not connect to my router, I cannot remember my WEP passphrase what can I do to get it working again
  • russem May 18, 2009
    Hi, I tried what you say and typed the router IP address but unable to login as I must have changed the username and password and can't rember it, so was unable to go any further?
    Scholar:
  • 58 Answers
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  3. Click Wireless Settings under Setup menu.
    1. Under Security Options, Select WEP (Wired Equivalent Privacy)
    2. Change the option to Disable
Posted on May 18, 2009
  • Divakar Kandasamy May 18, 2009
    Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
    1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
    2. Release the button.
    3. Wait for the router to reboot.
    4. Log in with the default password.
    If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
    1. Unplug the router's power.
    2. Press and hold the reset button. While the button is held down, reconnect router's power.
    3. Continue to hold the reset button for 20 seconds after reconnecting the power.
    4. Wait for the router to reboot.
  • 33 Answers
Need to hardwire ethernet cord to your router and go to start then run type cmd then type ipconfig into the black dos screen, this will give you a gateway address something like 192.168.1.1 depending on your router brand. Once you have the address insert into your web browser where you would normally type www.google.com and go to the wireless tab and retrieve the current wep key. Hope this helps
Posted on May 20, 2009
Netgear wg111t conection problem
  • log in to the netgear router's interface using www.routerlogin.com
  • username- admin , password : password
  • Click on wireless settings under setup . ( 3rd option from the top )
  • Under the security options .
  • U can find ur wep security passphrase to connect with netgear wireless.
In case of further assistance , do revert back
Feb 14, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
I have a wireless netgear usb adapter and nothing else, its not installed on my computer and I want to put it on, it wont work, what do i need to get my usb wireless adapter to work??? It is a wg111t...
You first need to install the driver. You can download it here:
http://kbserver.netgear.com/products/wg111t.asp (it should have came with your adaptor)
You must also have a wireless router available for this to work, or in an area that has WiFi available.
Jul 17, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear 108 Mbps wireless usb 2.0 adapter wg111t
i had the same problem. i tryed downloading the sofware from other computer and install it on the wireless computer. finally i just connected it directly to a lan line and update drivers with windows
Apr 08, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Wg111t wire network
run cmd ( windoowsxp) then type ipconfig you should see an address like 192.168.2.3 if not goto network conections and view all goto wireless connection -properties then tcip set for auto config and then ok make sure your router is set for WEP sercurity type in a ten digit hex code ( 28 34 f6 a7 c3) and then save . rescan for your network then log on make sure you have GOOD signal strentgh . the wg111t does not work well with belkin routers.
Dec 25, 2007 | NetGear WG111T 108 Mbps 802.11g Wireless...
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER
Configure router via ethernet cable in first instance. Then install adapter. May need to hange MTU for AOL as ISP.
Oct 08, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
NetGear USB 2.0-Stick WiFi 108 Mb WG111T (80229) 802.11g/b Wireless Adapter Logo
160 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
