Question about Canon PowerShot A590 IS Digital Camera
Camera turns on and off
Camera powers on and off by itself.
Where on the camra is the power.
Most home surveillance cameras have a "feed" (wires) to TWO separate gizmos: the camera itself, and the power supply to make the camera work.
The camera VIDEO wires will be the ROUND part of the wire, or "feed". That is because it is a "shielded" cable, kind of like the TV cable to your television.
The camera POWER wires will be "the other ones".
There is NEVER an on/off switch on a surveillance camera, and for a good reason: what the heck good would it be, if you could just sneak up on it from behind and turn it off?
If your camera is not powering up, I would suspect the power supply first, the wires to the camera second, and the camera itself third.
Good luck, and I hope I have helped you a bit with this information.
Mar 06, 2015 | Home Security
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
My sanyo vpcs1080bl turn itself off when powering on
Maybe the battery is dead. change the right battery
Jun 20, 2009 | Sanyo Xacti VPC-T700 Digital Camera
My camera keeps turning itself off and the amber light keeps flashing
Please check whether the battery is fully charged.
Please try using a different battery.
If the issue still persists after changing the battery try Power Resetting the Camera which should resolve the issue.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Camera turns itself off immediately even though it is fully charged
are you using rechargeable batterys or cheap ones
you have to get batteries specifcly designed for digital cameras or they wont power the camera properly.. try using different batteries !!
May 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Camera turns off by itself
I have a similar problem.. I recently found out it mostly happened when I was squeezing the right side of the camera or touching the card slot cover in some way... and I discovered that the camera turns off when you open the card slot cover, so it probably has to do with contacts that touch too easily and make the camera turn off when you shake the card slot cover somehow. Now that I know the source I'll see if there's a solution. Hope this helps!
Jun 09, 2008 | Fuji FinePix S7000 Digital Camera
Camera turns itself off after turn on
mine was same turned out to be flat batteries, bought 4 new and they did not have the power to run it ,went for durracell and it worked fine for 5 photo's, had to stick with re-chargeables and it works fine, good luck
Sep 16, 2007 | Panasonic Lumix DMC-LC50 Digital Camera
Olympus Stylus Powers itself off
the power on button is located under de lens slyding thing, therefore probably is broken or just need to be glued to do that u will need to open the camera. the other u will need to replace a small battery on the mainboard. good luck
Dec 04, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Auto Power Off function DiMAGE E223
Yes, the auto power save functions to save power. The camera shuts itself off after 3 minutes after the last operation
Sep 19, 2005 | Konica Minolta DiMAGE E223 Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
