Question about Electrolux Refrigerators
Won't make ice
Frigidaire Professional Series side by side refridgerator Model PLHS239ZCB1. Won't make ice but still provides water (slowly though).
Any ideas?
  • bjohns169 May 18, 2009
    No I haven't changed the water filter yet, but I am still getting water through the dispenser, so I thought the problem might be something else.
    thanks
  • 62 Answers
Have you changed your water filter lately. On many side by sides there are built in water filters that will slowly stop making ice and giving water because the filter is in need of changing...if this is not the problem write back and I will walk you through the other possibilities...
Posted on May 18, 2009
I just got the side by side Frigidaire professional and every few hours there is a loud noise that comes out of it that last like 3 seconds
Thanks for your post, friend!
I see that your Frigidaire side by side refrigerator is making a loud noise every few hours. There are a lot of normal operating noises within a refrigerator. It is possible that your evaporator may create a boiling or gurgling noise. Or you could be hearing ice being released into your ice bin. If you have your manual they should list some normal operating noises within your refrigerator. I hope this information has been helpful. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Frigidaire professional refrigerator
Sounds like you have a problem with water valve/triple solenoid assembly. It controls the flow of water to the door and ice maker. I believe it comes as a complete unit.
Dec 28, 2013 | Refrigerators
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Refirdgerator won't cool proprely on refridgerator side
Hi SN,
This could be a couple of things, but you should check for evaporator icing, even though you said the freezer is working and the defrost control appears to be ok. If the evaporator is iced up, no air willl flow into the fridge section even if the fan is running.
You can also check the damper control board. I am sending you a link that shows a complete breakdown of your appliance. I do not work for this company nor am I affiliated with them in any way. They also have a troubleshooting section and contact information. See:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5121995&diagram_id=29020886#d29020886
Aug 18, 2012 | Refrigerators
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
My model #Gi5svaxvl01 Frigidaire Gold, serial #k01911388, won't allow me to retrieve water or ice.
you tube is a great source of information I've pasted a link for you to follow.I hope this helps shannonhttp://www.youtube.com/watch?v=ECdu8xqf0Ns
Mar 07, 2012 | Refrigerators
Ice machine makes very little ice
I would suggest cleaning the coils under the front of the machine . Since it is making ice , but slowly , then the ice maker and water valve , are good . Dirty coils could be the problem .
Dec 06, 2009 | Frigidaire Professional Side By Side...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Refrigerators Logo
318 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
