Question about Palm Z22 Handheld
Touch Screen Fails To Sense Stylus
Most of the screen area is erratically sensing the stylus, if at all.  The lower portion containing the icons and spelling pad area does not detect any touch at all.
I have reset the unit and the screen is stuck at the prompt asking me to hit the targets; one in the upper left corner and the other in the lower right corner.  It just goes back and forth between the two targets.
I read a repair tip for this on older units.  I have partially opened the case (the top end of the case will not release from the body) and blew a can of air into the compnent board areas.  This did not correct the problem.
Thanks for your help.
  • 1 more comment
  • donguy Nov 10, 2007
    this is exactly my problem. I have been using a pen and paper agenda since August!
  • WML6067 Jan 14, 2008
    I have the same problem. Anyone have an idea on how to fix this problem.
  • Anonymous Apr 08, 2008
    Touchscreen of my palm z22 handheld is not sensing stylus. Menu is not opened. When Touchscreen in preferences is opened even target shifting is not done. Once tapping each target was easy, but now it is not working. So I could not Hotsyncronise to back up my data before hard reset. please notify me if solution is found.
    Problem Solver:
  • 16 Answers
I had the same problem and tried several of the solutions here, from cleaning around the edges of the screen, to soft and hard resets. They worked for a time, but eventually, the pointer didn't register at all. Before you throw out your unit, look on Ebay for the replacement digitizer. There are or were many when I looked, ranging from about $8 to considerably more. None of the low cost ones came with instructions, but did come with tools. Higher priced offerings were for having them replace the digitizer for you. I ordered the low priced one and figured I could figure it out. The tools they send are two tiny screw drivers with special tips and a small plastic device to pry the sections apart. If you want to do it yourself, I will be happy to explain what I did. Remember to be really gentle when you do every step. First use the pry tool on the place where the cord plugs in to connect the device to the usb slot on your computer. It is tight, but gently pry out the small black rectangle. You will see two tiny screws inside. Remove those, carefully with one of the screwdrivers that come with the digitizer and set them someplace save. These two screws or bolts have nuts, that you can't really see until the next step. Watch for them if they fall out. The next step is to use the pry tool around the edges of the white plastic face of the Z22 and separate it from the back. I would lay it on the back while you do this. There is a small u-shaped piece that is part of the reset button and it fits on a peg on the back part of the device. Carefully ease the front and back apart. There are 4 small screws that still need to be removed. Save them to replace when done. Remove the innards of the device, but Don't totally separate the sections. There are foil connectors that attach the parts and they need to be intact. Gently ease the digitizer from the white plastic face. It will have another white plastic box on it's back side. Use the pry device to separate the glass digitizer from that white box. You will see there is a gold striped foil connector on your new digitizer, about midway up the side of the device. Find the one that is connected to the old digitizer and ease it out of the slot. Remove the old digitizer. Slide the new connector into the slot. Position the new glass digitizer correctly over the white plastic box and place the innards face down into the white face of the Z22. Replace the 4 screws. Gently close the case, laying the front onto the back, so you don't displace the reset button part. Snap together and replace the two tiny screws into the section near the power cord connector. (Hopefully you didn't drop the little nuts out, during the process. If you did, you may have to back track until you can see the small white boxes that they slip into, in that location. Email me if you have problems with this. It sounds a lot worse than it was. When I finished, I was really disappointed, because it didn't turn on, the whole screen was black, which was worse than when I started. But, after I plugged it in, and let it charge about 3 hours, it worked perfectly! I am so excited! You can do this if you are patient and gentle.
If you partially opened the case, you may have had the restart button piece shift out of place. You need the tools that come with the new digitizer, or a very delicate tool to pry out the rectangle,around the power cord connection, and remove two tiny screws, before you can separate the front and back. The tool they send to do that is sort of soft plastic, tiny spatula shaped piece which can squeeze into the grooves and gently separate that piece and the front from the back.
Posted on Aug 19, 2010
What is the best stylus for the iphones
You probably won't like my answer, but the best stylus is your finger.
Apple made the capacitive touch screen so people shouldn't have to use a stylus pen. Older devices with a resistive screen need a stylus pen.
If you're used to use a resistive screen like on older GPS-devices, you need to adjust yourself to a capacitive screen of your iPhone.
-Don't try to touch items with the tip of your finger or nail.
-Even if you touch a letter on the phones keyboard with your thumb (which is maybe four times the size of the button), doen't the to touch it with the tip of your thumb. Place your thumb over the button, BUT MAKE SURE THE BUTTON IS IN THE MIDDLE OF THE AREA YOU TOUH WITH YOUR THUMB!
Just give it a try. Once you're used to it, you'll never want a stylus anymore. Everyone i know who ever buyed a stylus never used it.
Feb 15, 2015 | Apple iPhone 5S
Question mark appears on screen when I put a game inside of it.
  • Try calibrating the screen
  1. Turn the Leap Pad off.
  2. Now hold the question mark button for two seconds and then power the until on while still holding the question mark button down.
  3. The unit will power on and when you see the "calibration Screen" you can release the question mark button.
  4. Touch the crosshairs with the stylus and a large crosshair icon will appear in the middle of the screen.
  5. Touch this icon with the stylus and this will bring up the screen calibration procedure.
  6. Touch all 5 crosshairs as the appear.
  7. Press the "B" button to exit after completing the calibration.
Regards, Tony
May 11, 2011 | Leapster Learning System
Just received a used ds lite from ebay. when I type on the screen it enters the letter next to the one I touched. Is this a serious problem? Never used a DS before; will this have an impact on game...
Sounds like you should try recaliberating the touch screen. Calibration must be done with a stylus. Please note: Using a unlicsensed screen protector can lower the sensitivity of the screen, making calibration difficult. If the problem you are encountering started happening after installing a screen protector, this may be the cause of the problem. Remove all games from the Nintendo DS. Turn the system on by pressing the POWER button. Press the A Button when the "Touch the Touch Screen to continue" message appears. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button. should look like this :
icon_settings.gif Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button. should look like this:
    icon_calibrate.gif Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings. hope this helps
Dec 02, 2010 | Nintendo DS Lite White Console
How do you change system date on ds
SOURCE: http://www.nintendo.com/consumer/systems/ds/time_date.jsp
Changing the date
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Apr 15, 2010 | Nintendo DS Lite
I bought the new game zelda spirit tracks, worked well at the beginning. now the touch screen is very erratic does not respond with every touch. ?
try to re-calibrate your stylus..remove any game card..then go to system settings..you can see it on the lower screen like nds icon...then select the calibration icon...icon on your right like a cross hair..then restart nds after you calibrated..try your game...hope this help
Feb 19, 2010 | Nintendo DS Lite
Lost manual for cx4800- how do you clean heads- images are banding
If you have a printer icon in the quick-start portion of the task bar (lower left corner of the screen), Mose over it and see if it's for the Epson 4800; if so, right click the icon and you'll see the maintennce services listed
Aug 18, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Touch screen defective,
same problem here. Certain areas on the bottom of the screen dont work at all. Other areas I have to tap the stylus 20 times or more an hopefuly it catches. I wont be buying another phone from samsung.
Jul 25, 2008 | Samsung SCH-i730 Pocket PC
Nintendo ds
Setting the Time and Date
Changing the time
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
Changing the date
Dec 30, 2007 | Nintendo DS Console
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Palm Z22 Handheld Logo
317 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
