Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Fresh food section not cooling
Model -FRT22QRADO top freezer type. First off, I have both tstats at coldest setting. Dont feel much air at all through refr. vents. I'm trying to gain access to evap section to determine if frost buildup is the culprit. How do I do this?
    President:
  • 1,136 Answers
Hi, There should be 4 screws holding the rear panel on. The panel should then release. Make sure your evaporator fan motor is running also. You might find ice build up plugging the airway to the freshfood section. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 18, 2009
Replace fan motor
Hello Theresa;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on a label on the upper liner side wall in your fresh food section. So, I do not know what you have.
There are several reasons your fresh food section is not cooling:
1.) Cooling air vent from freezer to fresh food section. Find the air vent, put your hand in front of it, do you feel any air flow? This vent may be iced up or closed.
2.) Freezer cooling coils iced up - Look at the back wall of your freezer, is there frost or ice on the wall? You may have a bad defrost heater.
3.) Cooling coil fan - Open the freezer door do you hear the fan? Push in on the light switch, do you hear the fan?
Get back to me.
Peter Goodwin
Glen Burnie, MD
Jun 10, 2015 | Samsung Refrigerators
How can i fix it when kenmore type JD21, model 970-432603 refrigerator not cold but freezer is cold
Ice build up on the coils can cause this. If there is ice then you need to check the defrost timer first to see if it works. Then check the defrost coil, then the fan.
Jan 23, 2015 | Kenmore Refrigerators
Why is my kenmore freezer cold, but refrigerator not even when set at highest temp?
Hello Donna;
My name is peter. I am a retired field service refrigeration technician.
You have not provided your unit model number, which is located in your fresh food section on a label, on the side wall near the top.
You only have one cooling source, and that is your freezer. Your freezer feeds your fresh food section. This is through a direct air vent.
Reach into your fresh food section where the air vent from the freezer goes into the fresh food section. Do you feel cool air? Probably not.
So, either the air vent is frozen up with ice which you can clear with a hair dryer, or you have a automatic air vent motor/ sensor assembly that is bad.
Give me more information and I will help you.
Jan 21, 2015 | Kenmore Refrigerators
Fridge temperature keeps falling
Hello Todd;
You have not provided a model number so I can only speak in general terms. Your model number is in the fresh food section, on the top of the side wall.
You only have one cooling source. That source is your freezer which feeds your fresh food section.
1.) You have a vent from the freezer to the fresh food section. Put your hand in front of the vent. Do you feel any cooling air flow?
Depending on your model, you may have a bad air damper motor or temperature sensor which controls the damper motor to open and close. Or the vent may be blocked with ice.
2.) Check your freezer. Push in on your door light switch. Is your freezer fan running. You may have a bad fan motor, freezer thermostat, or be block up with ice. If that is the case, you probably have a bad defrost heater.
Get back to me with your model number and tell me what you have discovered, frost & ice in back of freezer? no air flow at damper? and anything else.
Dec 23, 2014 | Refrigerators
Our fridge seems to work like a freezer no matter what setting is on, is this a known problem? The model is a Gorenje fridge/freezer model: HZOS 3366
Hello Nick;
I assume you are from the United Kingdom based on your unit. I am from Baltimore, Maryland, USA.
Yes, this is a common problem and a simple one to fix. Your only cooling source is from your freezer. There is a vent from your freezer that blows cool air into your fresh food section. This vent is probably motorized and controlled by a temperature sensor in your fresh food section. Either the vent assembly is bad and stuck open or you have a bad fresh food section temperature sensor..
Temp fix: With tape or cotton balls or something locate the air vent to your fresh food section and block at least 1/2 of the air flow vent ports to your fresh food section.
Nov 13, 2014 | Refrigerators
Not cooling properly
First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the freezer and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing through the damper opening? Inside the freezer section, look at the back wall- any frost buildup there.
Hope this help.....
Jun 28, 2010 | Magic Chef CTF2125 Top Freezer...
Maytag MFF2258VEM French Door bottom freezer not cooling
Your model will and may take extensive diagnostics. You know there is no simple answer to this question and I will not guess. Do you have the sevice manual availible? I do if you need but from the length of your message it appears to me that you want and will need help. Let me know, Sea Breeze
Mar 12, 2010 | Refrigerators
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
two controls and both have capillary sensing.
The Auto Damper controls the fresh
food temperature and the Freezer Temperature
Control guides the freezer temperature.
The fresh food compartment temperature
is maintained by a damper assembly located
at the back of the temperature control
housing. Changes in air temperature
cause the damper door to open and close.
A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the
COLDEST position increases the flow of
freezer air into the fresh food section. The
freezer compartment temperature control
warms at a faster rate and cools at a slower
rate, increasing the compressor run time
necessary to maintain a satisfied freezer
temperature control.
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Zanussi zx99/5 freezer working fine but my fridge is too warm
This may be an airflow problem. These are things to check. Make sure the temp control in the fresh food section for both the freezer and the fresh food is set half way between coldest and warmest temp setting. Over adjusting these settings can cause poor air circulation and make the fresh food section too warm. When openning the freezer, the evaporator fan should be on or start shortly. If the evaporator fan stops working, there will be no circulation to cool the fresh food section and will need to be checked to see if it is bad. If bad it will need to be replaced. The evaporator in the freezer section may be iced over causing poor air flow to the fresh food section. You may need a service tech to check this part. If the evaporator is iced over, stopping air circulation, the button thermostat or defrost element may on the evaporator may be bad and could possibly reqiure a technician to replace it Check the first two things and let me know what you find and how it is doing after reseting the temp control. I will be happy to help you in any way I can..
Nov 10, 2008 | Zanussi Refrigerators
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
302 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
