Have a JSR 18240 radio, used only at home [garage], pulled plug out of power point without switching off, can't get working again, with power or battery. Is there a reset button?
My Delphi XM2GO MyFi has stopped transmitting to an FM station on a house radio. Is it repairable? If so, is there a facility in the Cleveland, OH area where I can take it?
IF you take it out of the home dock and run it on batteries, I'll bet you it works again. The newer home docks TURN OFF the FM transmitter. Try a car dock, or try it with just the power plug plugged into the bottom of the MyFi, without the home dock and see if you can now get the FM transmitter to work. Let me know. Thanks and good luck.
Aug 09, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Bought new battery about a month ago, everything until last week. Now my MyFi will not power up. What can I do?
Pull the MyFi from the base and plug the power cable directly into the bottom of the SkyFi radio - you should be able to power up with it plugged in directly, even without any battery. Give it a try and let me know.
May 18, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Printer error code 6202 when I start my printer
I unplugged the power supply several times. So far it seems to be working.
Jan 15, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
How to switch back to automatic after manually close the garage d
mikey-moore's advice helped me figure out what to do but it's not exactly what I had to do. Manually open the garage door all the way. Then hit the automatic button you normally would use to open and close your garage door. The bracket slides back and locks into place. Hit the automatic button again and the garage door should automatically close.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
try doing away with the external fm transmitter and use the one thats built in to the delphi you just go into settings and set it to a station that has no channels and tune it in
Jun 13, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Lift-Master garage door opener Model 1045-6 1/3 hp
Most residential garage door openers have a max. amount of cycles they can run per hour. Thus the difference between a residential opener which only needs to be opened a few times a day vs. a commercial opener which needs to open 10-20 times and hour. This could be your problem, you may be running too many cycles too soon. This would explain why it seems to work again after unplugging the power. You're resetting the unit. Hope this helps.
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Milwaukee job site radio
The transformer needs to be replaced. 120VAC to 15VAC. Take a look on amazon for it, here: Amazon com 15VAC transformers. Wish you best of luck.
Brust
Dec 02, 2007 | GE Superadio III AM/FM
Pioneer inno
I have the same issue. I was told a firmware upgrade will fix this issue
Nov 05, 2006 | Pioneer XM2go Inno Satellite Radio...
103 people viewed this question
 Grubhead
Grubhead
