Question about Dryers
Fridgidare dryer wont heat - Dryers
5 Suggested Answers
Ben-mrfixit
  • 68 Answers
SOURCE: Fridgidare dryer spins but no heat.
If the dryer runs but doesn’t heat, don’t even think it’s the thermal fuse. If the thermal fuse was the problem, the dryer wouldn’t run at all.
First thing to do is verify your source voltage for the dryer; for those of you in Manhattan, this means to use your multi-meter to measure the voltage at the dryer outlet to make sure you have 240v. Y’see, Slick, the dryer motor only needs 120v supplied by one of the lines to run. But the heating elements, on the other hand, need 240v supplied by both lines to get hot.
If the source voltage is ok, then the most likely bad parts are listed below. As always, you should use your meter and the tech sheet supplied with your dryer (and cleverly hidden inside the control panel) to verify:
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
Posted on May 05, 2009
  • 1531 Answers
SOURCE: dryer dosn't get heat. fridgidare
there could be a faulty heating element or thermal fuse. but check the main power and see if there is correct power supplied
Posted on Sep 17, 2009
  • 127 Answers
SOURCE: fridgidare dryer model GLGQ2152ES3 runs but does n...
ok, you can remove the small screws below the kick panel below the door on the front. that will gain you viewing space to watch and see if the ignitor is even glowing, if it is then you most likely need gas valve coils, or to turn on the gas.
if the ignitor is not glowing at all you will need to do some testing on the safetys and thermostats within the dryer. they are all closed at rest so you should have continuity through them. there is the operating stat on the air duct blower housing in the front of the dryer. there is also a hi limit that is on the rear housing of the unit that you will need to remove the top of the dryer to view and gain access to..
those dryers have been a pain and the rear hi limit is especially susceptible to poor venting practices so very common today, and the higher operating temps caused by the poor venting..
best of luck..
Posted on May 24, 2010
hunter19_46m
  • 7482 Answers
SOURCE: my fridgidare dryer quit heating
Try this...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me,
Posted on Aug 17, 2010
Fridgidare leq2152ee not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 08, 2011 | Dryers
Fridgidare Dryer Model #GLER34IAS2/Serial #XD40311703: dryer runs for about an hour then kicks out the breaker.
check the main terminal block and make sure there is no shorted wires.There is also a chance that the heating element has grounded out on the cabinet frame. causing it to draw to much power yet still dry clothes
Sep 12, 2010 | Dryers
My fridgidare dryer quit heating is it easy to repair
Try this...
Please rate me,
Aug 17, 2010 | Frigidaire Dryers
Fridgidare dryer model GLGQ2152ES3 runs but does not heat how do I get inside front or back to check the ignitor. It doesnt light (i think)
best of luck..
May 20, 2010 | Dryers
Washer and dryer capacities
4 cubic ft washer
7 cubic ft dryer
Feb 17, 2010 | Frigidaire FDE546RE Dryer
My dryer will not start. When I push the star button everything lights up but it will not start. It is a fridgidare and about 6 years old. It is an energy efficient Fridgidare.
Open the door, push in the door switch, press the start button and rotate the tub with your hand. If it starts running you have a bad motor. BE CAREFUL and this is obviously easier with 2 people but is possible with 1. Thanks for rating me after you view this.
Dec 12, 2009 | Dryers
Dryer dosn't get heat. fridgidare
Sep 08, 2009 | Frigidaire FEQ332E Electric Dryer
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
May 02, 2009 | Dryers
Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Sep 14, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
19 people viewed this question
Top Dryers Experts
