Question about Hmdx Burst Portable Rechargeable Speaker
I can't figure out how to charge
I can't see how orwhatto use use to charge it
How much does it cost to tune up a 2004 Rendezvous?
its a loaded question as labor rates and parts costs vary greatly depending on your location.
A six cylinder tune-up should run around 80.00 - $100 for labor and figure about $7 a piece for the platinum plugs your vehicle requires, so roughly $120 - $150 for plugs installed.
If you replace the wires there may be a slight charge to install and figure about $40 - $80 for the wires.
If you happen to have a coil with a corroded terminal figure about $40-$60 a piece for coils. There are three.
If you have the throttle body, valve and fuel system cleaner done, figure about $100 - $200.
The best way to find out is to call around some local shops or a dealer and see what they charge.
Jul 17, 2015 | 2004 Buick Rendezvous
On my heli raider the charging light wont come on
Just bought one, and charging light wont come on too. Plan on taking it back to the store. Did you figure it out?
May 26, 2013 | Toys
Samsung sl605 wont turn on
A charging battery's light is red. If it turns green then it means it is fully charged. Since you had stored your battery for a while, try to charge it by using a battery charger to kickstart it. It should work. Whatever transpires let me know. thanks and rate this answer.
Dec 24, 2011 | Samsung SL605 Digital Camera
Gauges don't work, battery goes dead, ignition changed, battery changed, alternator changed problems presists
Charge battery, start engine, then touch the small terminal on the altenator momentarily with a jumper lead from the hot terminal on the alt. Charge light should go out and batery should be getting a charge. why it does that i still can't figure it out, but it works!
Nov 24, 2010 | Jcb Bruder JCB Loader Backhoe
My refgr.'s compressor is defective according to service engineer.it's within warrenty period. should i pay the charges of gas filling.
Yes, most any manufacturere will pay for the materials, but NOT the labor...yeah I know it stinks!!! You buy new and figure you have a warranty and then they wack you with labor charges anyway... go figure...
heatman101
Aug 07, 2010 | Whirlpool Refrigerators
Fails to charge, even after replacing battery
It's a common issue with the main sysytem board, it needs replacement
May 21, 2009 | Dell Inspiron 1000 Notebook
Lost directions to charge battery
you need to charge the specific power wheels charger into your battery.
I have a power wheels jeep and a peg perego gator but had to get 2 different chargers for them.
I charge my batteries up for about 18 hrs at a time and they seem to run fine.
Apr 25, 2009 | Jeep Yellow Sports Outdoor Power Wheels...
Craig mp3 player
u have to plug the usb cord into the computer with the computer on an then it has to be in the mp3 screen then it charges
Jan 02, 2008 | Audio Players & Recorders
Hmdx Burst Portable Rechargeable Speaker Logo
Top Hmdx Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hmdx Audio Player and Recorder Expert? Answer questions, earn points and help others
