Question about Panasonic DMR-E85H DVD Recorder
Finalizing a dvd fails to complete function.
Before completion of finalizing process (approx 1/4 along), machine switches off.
It comes back to life after a while but the dvd has failed to finalize. Trying to finalize it again, produces a message displaying FINALIZE FAILED. The disc will play on the machine, but not on any other machine. Putting it into another machine gets the message that the disc is blank?
  • Rick Bryant May 11, 2010
    If the dvr is in HDD an not DVR it won't finalize the disc
    Problem Solver:
  • 13 Answers
The power supply board on the DMR-E85H has problems. The earlier boards suffered from leaking capacitors and the later boards from voltage regulator problems. Go to the following links for details and photos on how to fix: Replacing capacitors:http://www.fixya.com/support/t216825-dvd_recorder_frozen_please_wait_display Replacing the voltage regulator:http://www.rbjtech.net/electrical/e85/e85.htm#0 Hope this helps. My machine had the same problem and has the later ps board. The voltage regulator replacement worked perfectly.
Posted on Jun 05, 2009
  • Kelvin Harley Jun 05, 2009
    Before you try the power supply board repair, I would recommend you get a CD/DVD cleaning disk. This is basicly a CD with tiny cleaning brushes. You should be able to get one from a computer accessory store.
I got a new machine, when I transfer from VHS to DVD-R it records, but will only play on the machine I recorded on, it doesn't load on other DVD players, why is that?
You need to FINALIZE the DVD-R you recorded in that unit for it to be playable on other DVD players. This function should be part of the on-screen menu for your unit. (in Panasonic DVD recorders, it's under DVD MANAGEMENT in the FUNCTIONS menu).
If the disc you recorded is already loaded, but stopped, press SETUP on your remote - an on screen menu should appear.
Using the UP/DOWN arrow keys, select DVD MENU and press ENTER. Use the UP/DOWN arrow keys again to select FINALIZE and press ENTER.
A message box will popup 'Finalize disc?' use the UP/DOWN arrow keys to select YES then press ENTER. Finalizing should start and may take a while to complete.
Once complete, the disc is now playable on other DVD players. (from page 32 of the owners manual with the heading 'PLAYING THE DISCS IN OTHER DVD PLAYERS')
Feb 10, 2013 | Toshiba DVR620 DVD Recorder/VCR
DVD Finalization
im guessing your talking about a new disc here , before you can do anything with the disc ,you will either have to format it or erase it, once you have donr that you can then use the disc and edit its contents. im assuming you are using the correct type of disc for your machine, eg dvd+rw or dvd-rw check the manual to make sure your machine can record onto a dvd+rw disc. hope this is of some help to you.
Mar 15, 2008 | Hitachi DZ-MV550 DVD Camcorder
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Hi: Please i have the sony handycam model:dcr-dvd602e and i had recorded a whole disc with it ( 30 min.) then i finalize and it was completly finalized but after that or at the end of finalizing a message...
oops....something happened during the finalizing process and it failed. Hope you had a back-up in your computer of the disk. It doesn't need to be finalized to have it in the computer, just in case this happens. Looks like your disc got erased.
Oct 30, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
We have a GoVideo vcr/dvd recorder, but I cannot find the model number. It has a date on it of Sept., 2004. We have a video tape taken from a Sony camera, suing a Mini DV 6 tape and transferred it on...
Sorry u can't do anythings to the finalize codes,the dvd coppy process,the machine auto finalizing progamming codes belong to that machine done it by itself.Some compannies protect it softwares codes don't share with other in the industries.That why some programming codes copying dvd is finalizing in one machine.Can be used in that machine only or it partners olny.Check,if the dvd can be play in the computer?Buy a DVD coppy software for a computer.Recopy the DVD throught the computer software.The computer softwares have common sharing finalizing codes in the industries.U will be able play it in any DVD players.
Sep 17, 2010 | GoVideo Go Video DVD/VCR Combo
DVD burn with DVD X-copy not completing finalizing mode
"Is this what is causing the "finalizing" to not complete the burn?" ... Almost certainly yes. You need to update/reinitialize your Patin Couffin engine device drivers(s).
Referer: http://www.free-codecs.com/download/Patin_Couffin_access_layer.htm
Download: http://www.freecodecs.net/fc/patin-couffin_37.zip
  1. Download the stand-alone installation package.
  2. After download is complete, close all other applications, then run it.
  3. Restart (reboot) your system.
  4. Test by re-performing the same procedure(s) which previously failed and generated the error dialog (pop-up).
"Today's the best day of my life...and NOW you're part of it!"
Dec 10, 2008 | 321studios DVD X Copy Platinum (200000)...
Finalizing dvd
Unplug the device from the outlet and wait 15 seconds before plugging back in. This will reset the device and stop the process, but it will not complete the process so you will have another incomplete dvd. Once you plug the device back in, you should be able to open and remove the disc and all functions should be back to normal. Let me know if you need further assistance.
If you do not mind, please rate my help I would greatly appreciate it.Thanks
Aug 14, 2008 | Panasonic DMR-EZ17 DVD Recorder
FINALIZING ISSUE
Press FUNCTIONS button;  Select DISK INFORMATION; Select FINALIZE; YES; START; ENTER.
Jul 18, 2008 | Panasonic DMR-E50 DVD Recorder
Finalizing DVD
If you unplugged the recorder while this process was ongoing, it probably failed. You will need to record again.
Have a great day! :)
Nov 29, 2007 | Sony RDR-VX500 DVD Recorder/VCR
Won't complete finalizing
SAME PROBLEM AND IVE TRIED ALL TYPES AND BRANDS OF DVDS. IM RETURNING MY P.O.S. , DONT WASTE ANY MORE OF YOUR TIME OFF FOOLING WITH IT
Sep 03, 2007 | RCA DRC8335
Panasonic DMR-E85H DVD Recorder Logo
351 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
