Question about Hitachi 43FWX20B 43" Rear Projection Television
Convergence slowly change red moved about 3 inches all over screen
Red drifted to right over a period of days to about 3 inches off alignment,I search the web and found that the fusible resistors might have blown,checked ok,Unit has stk292-110 2 of them and they were hot,I also was shown that a suitable replacement was the stk 292-150,I did install them now I have sound and no picture,the stk heat-sinks are still hot ,so I've stopped at this point for assistance and to find a schematic for this set,
Any help or comments would be appreciated. will the 150 replace the 110's?
Thanks,
Gene
  • fixit r Oct 19, 2007
    hi, I made a typo,stk 392-110. I did sub in the stk392-150 working good so far.
Hey,I am not a pro at this and this is just my story ,It's fixed and running good....here's the story,The problem was the red convergence lines drifted to the right over a period of days,couldn't watch it no more ,pulled the plug!
Search the net and found this site,others here are having about the same convergence problems too,I first went into manual mode and moved the lines around with the remote,no good too far out to bring back,back to this site,found most problems related to convergence belonged to STK 392-110,yep I had them in my hitachi 43fwd20b,I did plug it in and turned it on,those big heatsinks got hot quickly so I figured those are the problem,also I read that several fuses near them could blow,so I checked all of them around the STK's for opens and correct values,they were all good,so I order 2 STK 392-150,I had found another post that said the 150's would work and also the 180's,I used the 150's and they work fine and are running fairly cool,I did add a fan to those heatsinks and also one on the dm board.ok here's how I replaced the STK's ,DO make sure the power cord is unplugged,remove the lower cover ,the black tray that holds the circuit boards slides out,there is only a few screws holding it in,a bracket that has the red wires has to be loosened 2 screws,I removed all the wires from the holders,because they keep the boards from sliding out far enough to tilt them up and release the power board with the STK's there are a few plastic clips that hold the board to the black tray and also wire connectors that are on the next board over to your left lift up to open,they have a small tab on then,I used a flat blade screwdriver to lift them once I had the tabb pressed,once these are free the circuit board will come up out of the tray,I stood the board up vertically and resolder each pin on the STK's,then used a solder sucker to remove solder from each pin,turn the board down,each STK has 2 screws holding them in,remove the screws with a long philips screwdriver so you can reach over the heatsinks in front of them.BE Careful not to slip when doing this,one nick from a screwdriver can damage traces on the board ,once the screws are out you might have to pry them off the heatsink,I did this with a steak knife.The heatsink compound was hard and dried out,I removed it with fingernail polish remover and a rag,when the new parts arrived,I put new heatsink grease on them(i used quicksilver) and reinserted the stk's,do the furtherest one first,be careful to make sure the pins go in the right holes,then the 2 screws do both of them to this point,then turn the board back up and solder each pin to the pads,If your not good at soldering,practice or get someone that can.put it back together.I left the back panel off
and removed the four screws that hold the front on that has the speakers in it.I did this to set up the screens and any other adjustments,I plugged it up and turn it on,connected the cable,got sound with no picture,found the picture tubes didn't light up,bad connection?yep found a connect near the power board it had 2 wires red and a blue that wasn't pushed down,after that I had a picture,now get the manual or go search for how to do a convergence,and follow it step by step and you'll get it done .This took me about 4 hrs,But now I have a much better picture and the convergence is right on! feel free to add on or correct as needed,,,,,Thanks!
Posted on Oct 24, 2007
My screen looks like its 3D.
Your tv has a problem with the convergence, adjust it using the original remote go to the setting's menu then go to the convergence section. Adjust the convergence color red and blue the green color is your guide you cannot move this green color, then you should move the red and the blue in all direction left to right, up and down. If you cannot move the red and the blue far enough the convergence IC is defective it must be replace in order to align this convergence. Feel free to send feed back good day and best regards.
Aug 14, 2011 | RCA HD56W66 56" HDTV
Flash Focus does not correct convergence problem and i cannot manually adjust the red convergence to proper alignment. Red does not move laterally only vertically. Picture is offset to the right with red...
No,any colors lines mis alignments.The tv convergence board parts are dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be replace on the tv convergence board.To solveved convergence problems.The shop,will cost u $300-350 for parts and labors.
Aug 10, 2010 | Sony KP-51HW40 51" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
The Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Apr 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50FX20B 50 inch: Blue Convergence --will not adjust
You need to change convergence amplifiers. Should be no problem for a professional
Apr 08, 2009 | Hitachi 50FX20B 50" Rear Projection...
Red Convergence
http://schematicscom.blogspot.com/
http://homenol.blogspot.com/
Visit these sites. Convergence procedure of projection televisions are given in detail.
Mar 28, 2017 | Televison & Video
CONVERGENCE PROBLEM IN TOSHIBA 43H70
Replace both STK392-110 convergence IC's with Toshiba or Sanyo brand........no cheap junk IC's !!!.................T.
Aug 16, 2008 | Toshiba 43H71 43" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
157 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
