Vacuums Logo
A
Anonymous Posted on Dec 28, 2013
Ergorapido CT120NI Motor Cuts out after running only a short time
Where do I plug the charger at to an ergorapido by Electrolux
Which model do you have? The Ergorapido EL1014A has a charging station. On that model, the charging adapter plugs into the port on the bottom of the floor section of the charging station. This port is below the wall section of the charging station. For the Ergorapido Lithium Ion Plus 2 in 1 vacuum, EL2055B, the charger plugs into a port on the back of the main vacuum above the neck to the roller brush head. For a picture of the charging port location, see https://moderncastle.com/vacuum-cleaner-reviews/electrolux-ergorapido-vacuum-review/ . Scroll down to the Battery section to see the appropriate image.
I hope this helps. The manual for the EL1014A is much clearer about charging the vacuum.
Will not maintained power in high setting. Runs fine in low power setting.
I would recommend thoroughly cleaning all filters, most likely the high setting is overheating the motor and the thermal protection circuit is tripping. In other words, the motor isn't "breathing" well.
Electrolux ergorapido plus
Christmas 2013 I was given an Electrolux ergorapido. I put it on the charger and red light won't come on or if it by chance does it flashes three times and then cuts off.
Aug 13, 2013 • Vacuums
3helpful
2answers
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
7helpful
2answers
My electrolux ergorapido wont power on . Have only used it a few times. It has been on the charger for approximately 2 weeks without use.
If it will not come on there are several things you need to check. First off you should call and have your model type and serial number checked to be sure your unit isnt affected by the recall they had due to expanding batteries. Second you do have a 2 year warranty on the unit and if it wont even turn on there may be a defect. Are the blue charging lights coming on? If they are and your transformer is warm then there is more then likely a defective battery in the unit and you should contact customer service at 1800-896-9756
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
