Question about Philips GoGear HDD6330 MP3 Player
Re; replacing the screen,
re replacing the screen,
i had the same problem,
got the thing apart no prob ,
but not sure on the connector for the screen,
pulled it away from the circuit board,but any advice on geting it reconnected would be appreciated,does not look like a simple push in job,
thanks
  • madfrozen Oct 21, 2007
    You is the man,
    just the tip i needed.
    thanks for your help.
    New Friend:
  • 161 Answers
To remove  the LCD screens ribbon cable, the thin black line to the right of the screwdriver tip is the cable clamp, this needs to be gently hinged upwards using a very fine flat blade screwdriver to about 40 degrees, full across the top of the connector working from the ribbon cable side, you will find the cable becomes very loose, and easily removed or reinserted. BUT please take care its delicate !!
Posted on Oct 19, 2007
  • Eric Mason Apr 21, 2010
    I should add, " when re-inserting ribbon cable, making sure its fully inserted and square, lower the clamping bar and push down " this locks the ribbon cable in position
Sony bravia lcd won't power on after lightning strike
I am sure the tv is shot from the surge but you can check a few things. I would take the tv apart and test the power supply first. Look for obvious burn damage throughout the boards. If there is a blackened one (prob video board) then you can try to replace that. Don't worry about taking this apart and breaking it further. In this case it can only get better for you.
Oct 06, 2012 | Sony BRAVIA KDL-46EX400 46" LCD TV
I took apart my ds lite to replace my shell, now the on light comes on for around 5 secconds and the bottom screen flashes?? its not the battery as i have tried many things? can any 1 help me
Hi there, when one of the screens flash it usually points to either 1. The screen being faulty or 2. The screen connector has not been put back in correctly.
As it is the bottom screen that flashes it is the top screen that has the fault. Check the cable is seated into the connector properly. Remove and reseat it if necessary. Also check you have not damaged the ribbon cable connector going to the top screen as this will cause the same problem
Hope this helps and thank you for using FixYa
May 30, 2011 | Nintendo DS Lite Console
Touch screen doesnt work
Hi, it's possible that the ribbon connector for the screen isn't making good contact.
I recently repaired my son's with this problem.
I took it apart and put a piece of masking tape over the connector clip and it's worked ever since.
I f you want to have a go there is a video on youtube which demonstrates how to replace the touch screen, it will show where the connector is.
Dec 24, 2010 | Nintendo DS Lite Console
Replaced screen lights up ok no picture
Take it back apart and make sure the connectors to the lcd are properly seated and locked down tightly. This is usually the cause of the white screens.
Jun 14, 2010 | Nokia 6300 Cellular Phone
Replaced speed sensor on 93 honda accord and speed odometer
it's only a couple of things that could be wrong. if you already replaced to speed sensor make sure you have power and the connector. but it's prob you gauge
Sep 03, 2009 | 1993 Honda Accord
My phones display lights are not working.
Friend, it is in the keypad/light interface be sure it is firmly attached.press a little of that connection to restore the lights.
Jul 11, 2009 | Sony Ericsson Walkman W810i Cellular Phone
LCD replacement
I've done few myself its not that hard really you jsut have to have the confidence to pull bits and expect the odd loud sound to be made when u take the lid apart.
The screen will have a ribbon connector which jsut plugs directly into the motherboard and a (usually black) power connector as long as you notice where the old one plugged into you will be fine.
A few pointers when dissassembling the machine , make sure you take out all the screws even those hidden ones that mybe in the battery compartment or hiding under stickers, make sure you work on a flat surface away from carpet and static electricty , before you touch the insides of the computer discharge any static build up you have by touching metal and when replacing the screen be sure to tuck in the wires so they fit snug in the case so they dont get snagged when you shut the lid.
There are no real secrets really just use common sense and take it slow
Goodluck
Aug 19, 2008 | Compaq Presario M2000 Notebook
Screen turns white
most common prob on v3 model is its flex connector.  try replacing it or look for a technician who can handle the job. im sure your prob will be solved...
Oct 12, 2007 | Motorola Mobility RAZR V3
HDD6330/17
Hi -- as you say the rear metal case needs to be removed, best start around earphone connection, use thumbnail or thin stif plastic,ease under metal case in and work across top, then bottom sections then onto the side (on/off)switch there are two plastic "tanges" about one third along then two thirds along that need to be pushed inwards and upwards.The other side again two "tangs" but both these two are in bottom half only, at quarter and half way position. Please be very careful and dont insert tool to far 2-3mm at very most.
Sep 21, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
77 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
