Question about Xerox DocuColor 12 Printer
Dirty output on smooth colours
While printing fountain fills in Corel Draw or shadows, gradients print dirty, a very pale pink colour may print as it would be grey. The final white colour in a gradient print grey. So very nice pictures print very bad. Any suggestions? Thanks in advance.
  • mag162 May 19, 2009
    Thanks for Your time, jbussine! If I could perform a calibration I would, but it has no scanner and there are no chances to find an attachable external calibrator in the place and around. Thought that it could be an issue already fixed by smbd. Will be digging on.
    Problem Solver:
  • 5 Answers
Ok need a little more specifications :) after researching the product a bit there seems to be a few variables. Such as if you are using the Splash server, Fiery Server or the Matchprint Professional server.
This is the link to the support page for your product
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?LBound=1@31,St=322,E=0000000001440901325,K=8114,Sxi=5,t=Browse.tem,varset=CFROM:31
what i could find is that it sounds like you will have to perfrom a colour calibration for the printer to correct the colour issues. Once again the instructions vary depending on the server your using.
This link is to the "how to perform a colour calibration" section for your printer
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=24,E=0000000001440901835,K=8114,Sxi=9,UseTemplate=Browse.tem,Remove=All,Problem=obj(8226),Query=%22%22,VARSET_RestrictFolderSearch=Perform_Color_Calibration_DC12
you will have tofind the correct entry that matches the tool set that you are using.
Best of luck
Posted on May 18, 2009
Why xerox phaser 6360dn is printing only pink
Anonymous, Have you tried to print the test print, is that Pink?
Have you tried too print the configuration sheet, is that Pink?
Have you tried to run purge sheets are they Pink?
If the answer is yes to all the above then has the printer been moves whilst still hot or warm, you could have mixed the colours.
If all the colours were mixed together then you would have a dark dirty Brown. Further investigation needed.
Good Luck.
Sep 05, 2014 | Xerox Phaser 6360 Laser Printer
HP 9050 with smeared or Ghosted print on the leading edge
Your printer might have dust on the hexagonal mirror and other optical components inside the LSU (Laser System Unit). If the printer it's dirty inside, all that dust flows and lay down on components. In course of time, it reaches the optical components and generates a "gradient wiped out" image from left to right as you are looking at the printed page. This problem is common on laser printers. On colour printers, you may find that only one or more colors have this gradient wiped out. Because they have separate Laser System Units.
May 08, 2014 | HP LaserJet 9050 Printer
Oki not printing pink
Seen this many times. Its because you are using recycled drums and/or toner. With the genuine items you will find the magenta will be more red than pink.
Jun 15, 2017 | OKI C9600hdn Laser Printer
We have a HP Color Laserjet 3600 printer. Printing a text, the right side is very pale. Printing pictures, they turn out unclear with strange colors. We have new cartridge
The laser unit on your machine may be dirty,
The first colour that normaly goes fuzzy is the red.
The problem may also be on your fuser unit,
Rub your finger over the printed area, and if the image gets smudged the fuser unit isnt fusing the toner proprly
Feb 10, 2011 | Office Equipment & Supplies
Replaced cartridges
Hi there :
on mine i had to use some rubbing alcohol and clean the new cartridge and the contact area on the p[rinter then reinstalled the cartridges and kept running the cleaner program and then about 15 sheets of paper later it finally cleared up and the color returned to normal and i had no more prohblems
Mar 07, 2009 | Canon PIXMA iP2000 InkJet Printer
Corel-DRAW 12 UNABLE TO EMBED (COLOR) JPG ONTO COLOR BACKGROUND
Right click the graphic and choose the image tools and you wil find an option for color and one for B&W. Play with those to find the problem. That should solve it
Michael
Feb 26, 2009 | Corel WordPerfect Office 12 Standard...
After preview with correct colour, print comes up pale colours.
Have you confirmed that the scan you are trying to print is good?
Dec 13, 2008 | Canon CanoScan N640P Flatbed Scanner
Printing special effects from corel draw on Eltron p310
Try looking for an option in printer driver Graphics settings which prohibits black panel printing
Nov 15, 2008 | Zebra Eltron P310 Thermal Printer
Printing blue on top of pink
There is a common colour problem with this model printer it is caused by the scanner assembly (there's a fan that blows megenta into the scanner unit).
Solution is to clean the scanner mirrors.
Aug 04, 2008 | HP Color LaserJet 2600n Printer
Xerox DocuColor 12 Printer Logo
303 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
