Convergence amp I have a Toshiba Model 42H82 TV that the convergence amp was replaced about 1.5 years ago. Now the convergence is acting up again and the outside alignment won't adjuct to correct the double vision on words and pictures. How long should a replacement convergence amp last and how much are they to replace? I know the part can't be more than $30 but a repair man will charge est $500 to fix. Do you recommend doing it yourself? How hard would it be to fix for a novice? Where can someone buy the part?
  • 8,617 Answers
You usually have to replace the two ICs at the same time along with resistors to get the longest life from the Convergence amps. You can get the repair kit for your model at the following link which contains both ICs and all 6 resistors plus instructions with pictures that explain how to do the repair yourself. Heres a link to the correct kit for your model Toshiba.
http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
Posted on May 18, 2009
Touch focus error blue
The tv HYPER board it is dead aslo known as a tv convergence board.Tv have a convergence problems,it is dead.Tv Magic Focus button no longer response give error messages.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?Yes,than the tv HYPER board it is dead also known as a tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of resistors too.To fixed the tv HYPER also known as a tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 12, 2011 | Toshiba 42H82 42" Rear Projection...
Focus Error I am getting double picture and the colors are off. When trying to auto focus the blue lines are wavy.
Replace Convergence ICs ,Big black ICs will have PN# on them example STK 392-110
Mats has ICs 1-800-628-1118
Jun 05, 2011 | Toshiba 42H82 42" Rear Projection...
Seeing double colors don't line up
This is usually a convergence problem that can be as simple as poor connections at the convergence ICs or defective ICs. Please confirm your model number (42H82) and whether or not you wish to attempt the repair yourself and I will provide additional details and instructions.
Thanks,
Dan
Aug 19, 2009 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82 Blue raster is bowed to the right in the middle to the rt. The auto convergence give an error.
You have convergence output failure. The output ICs will need to be replaced and possibly a small component like a resistor or two as well. Expect to pay a service company $350-$450 to resolve this.
michtech
Feb 16, 2009 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 convergence resistor and pico locations
yes better.  you need schmatic. servicemanuals.net.
Dec 13, 2008 | Toshiba 42H81 42" Rear Projection...
Have a Toshiba 42H82 rear projection TV
Sounds like a power supply problem. You will need your tech again.
Nov 13, 2008 | Toshiba 42H82 42" Rear Projection...
Blue Convergence on Toshiba 42H82 42-Inch
it should just need new STK392-110 ICs which is actually not very difficult. You will need two ICs both STK392-110 and you can get replacements at the following link and they provide instructions on how to remove and replace Convergence ICs.
Heres the link.
Oct 22, 2008 | Televison & Video
(6) 1.8 ohm 1watt metal film resistors for R7711, R7716, R7721, R7726, R7731 and R7736 yes the STK 392-150 will work fine.
Sep 24, 2008 | Toshiba 57H82 57" Rear Projection...
Question regarding toshiba 42h82 not 42h81
This is like a quiz right?? Let's see ;;;;;;; by convergence resistors I assume you mean the yoke return resistors out in front of the amps. There are 6, in the 2.2ohm 1w range, easy enough to find. The value of the convergence amps, that unit uses two stk392-110 Sanyo original Ic's rated at 6amps. You can use stk392-150's or stk392-180's just a higher amp rating. The two pico fuses in that circuit are F851 and F852 respectively.
Hope I get an "A"
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Sep 24, 2008 | Toshiba 42H81 42" Rear Projection...
Convergence problem????
Yes Its the stk Packs,They are usally 18
Jul 23, 2007 | Toshiba 42H82 42" Rear Projection...
Televison & Video Logo
218 people viewed this question
Top Televison & Video Experts
