Optoma DCD1 instruction manual
Service manual how do i take the cover off of my optoma EP721
Service Manual for Optoma series projectors.
http://easp.optomausa.com/ASP/upload/Optoma%20EP721_EP727_EP723_EP728_EW1610%20Family%20V6.0%20%28DDP2230-USB,%2036.88N03G001%29%20Service%20Manual.pdf
Aug 26, 2014 | Optoma EP721 Projector
Optoma ep 1690, the on/standby led is flashing green but when I try to turn it on the temp and lamp led's flash twice and nothing happens, the on/standby continues to flash green.
The projector lamp life may have exceeded its safe limit, check your instruction manual, sometimes you have to hold the on or off button for 10 seconds to reset this. All manufacturers are different but that may be the problem.
Here is a copy of the manual, I havn't read it, my solution is from experience of other projectors.
http://www.myprojectorlamps.co.uk/projector-manual/Optoma/EP1690.html
Good luck
Aug 04, 2011 | Optoma EP1690 DLP Projector
I need instruction manual for DS3061 optoma projector
Does Optoma support that model anymore? I was unable to even find it on their website... like anything for that model.
Try taking a look at this model, it looks similar to the one you are asking about and they probably work the same. The link to the User Manual is on the upper right of the webpage.
http://www.optomausa.com/Product_detail.asp?product_id=525&itemno=EPDX606VB
May 03, 2011 | Computers & Internet
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
Were can i get a replacement remote for optoma 700x
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
Or try ebay by description.
I hope this helps.
Dec 29, 2010 | Optoma HD700X DLP Projector
The optics are dusty in an Optoma HD32 projector, I require a service manual which would indicated the correct method to remove, clean and reinstall the optics.
go to http://www.tantht.blogspot.com/ . He has excellent instructions for dismantling an optoma projector. However I took it one step further. I still had a problem with overheating due to dust after I followed his steps twice. Then I also removed the back of the projector which gave me much better access to an internal fan. I could see a substancial amount of dust coming out when I blew compressed air through it this third time around. It has been working fine for 6 months since.
Jan 25, 2010 | Optoma HD70 DLP Projector
Sound from projector
All you ned to do this is a Scart to Phono lead from any good elctrical store and follow the instructions in your projector manual and the freeview units manuel .. ... Reagrds vortash
Oct 16, 2008 | Optoma HD72 Multimedia Projector
Optoma sw51u- lost remote control
Best chance is linked below but you will need the remote's model/part number at hand since the site couldn't find that model number:
http://remotes.com/remotes/servlet/rs?a=Search&mode=brand&uuid=12207196615740&brand=OPTOMA
Sep 05, 2008 | Audio Players & Recorders
I have no instruction manual supplied
The user manual is a CD-ROM and I was unable to locate it for download. However, try to contact them with the info below. Maybe you could purchase the CD-ROM, or they could email it to you.
Optoma USA
715 Sycamore Drive
Milpitas, CA 95035
Phone: (408) 383-3700
Sep 02, 2008 | Optoma EP709 DLP Projector
jasbo
jasbo
