Question about Pride Jazzy 614 Hd JAZZY 614HD
Real slow moving forward and turning
Chair has new, charged batteries and is still super slow and will barely turn.
dromtonpa
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
  • 175 Answers
SOURCE: the battery is charged but the lights just flash
Make sure the charger is unplugged from the chair and that the chair is in gear. There's two levers that place the chair in freewheel, or neutral so you can roll it around. Place these in neutral, then back in gear firmly. If still flashing, turn chair off, wait three seconds and turn back on, then push on the horn button three times. This will take it out of sleep mode. Still not going, you will need to check all clip-on connections to make sure they are tight.
I am assuming that all of the lights are flashing constantly. If it flashes a "fault code", you will get a series of flashes from 1 to 10, then a pause, then a set of flashes. Count the number of flashes and it will tell you what the fault is for that number of flashes in the owners manual. If it is just two red lights flashing constantly, you have a set of dead batteries.
Good luck.
Posted on Jul 11, 2009
  • 13 Answers
SOURCE: Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Posted on Feb 02, 2010
SOURCE: Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Posted on May 18, 2010
Testimonial: "That was the problem, Thanks !!!"
  • 31 Answers
SOURCE: My Pride Go Chair battery appears to discharge
Yes prob one of the batteries are bad, but you may want to replace both.
Posted on Jun 26, 2010
I have a pronto m6 , I replaced the batteries and it will move and turn ok but is real slow and no power .
Test the battery voltage at the joystick where a programmer or charger would plug in. There are 3 holes, the top or number one hole is the positive hole for a voltage meter to plug into and the bottom or number two hole is the negative hole for the volt meter. Plug in the meter and see what the voltage is when sitting still and keep the meter in and see what the voltage does while you are driving the chair. The voltage should not drop more than 1 or 2 volts from that which you had when the chair was not moving. If the voltage drops more than that then there is a problem with charging or the new batteries. If the voltage remains good then the joystick or speed knob control could be the problem.
Apr 26, 2015 | Invacare Supply Group Pronto M61 Standard...
What does my tss300 power indicater keep flashing left to right but won't move. batteries are fully charged and reset is set?
The chair is more than likely in free wheel. There are two levers under front of the seat (yellow). Pulling them forward should place the chair in freewheel and pushing the levers back should place the chair in drive. Once in drive mode, turn power on to reset joystick.
Apr 27, 2014 | Pride Mobility Pride TSS300 Power Chair -...
Go Chair goes slow
check the breaks are not sticking on.
slacken off or remove to try if this is the fault
Jun 02, 2013 | Pride Mobility Pride Go-chair Travel Power...
To slow, i need it to go faster
Are your batteries fully charged? Are the batteries 2 years old or older? Even with a full charge older batteries will not generate amperage to make the chair go as fast as when new. Also the motors tend to slow down with age due to brushes wearing down. Now, if the batteries are new and the motors are not that old then you need to find a wheelchair provider that has a PP1 programmer and have then check the settings for forward speed etc. If the speed is not set to 100 then they can increase the forward speed to 100%. Hope this helps you
Sep 21, 2010 | Jet 3 Ultra Power Chair
Wheel chair won't move. Batteries have been charging for several hours and have some charge but chair will not move.Any suggestions? Thanks
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
Aug 22, 2010 | Pride Mobility Products New Pride Mobility...
How do i get my power chair going after its all fully charged? wat do i press to turn it on get it going?
press the top button on your joystick the lights on the joystick will come on showing battery charge and speed wait about 5 seconds then push the joystick forward and away you go I would suggest placing the spped on slow until you get used to driving the chair
Aug 15, 2010 | Golden Technologies Alante' Power Chair
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Red light on my jet 7 keeps blinking and chair barely moves.
Sound like the batteries are on their last leg. Have them load tested.
Jul 17, 2009 | Jet 3 Ultra Power Chair
Pride Jazzy 614 Hd JAZZY 614HD Logo
29 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
