Question about Kenwood DDX470 - DVD receiver - display 6.1 in - in-dash unit - Double-DIN
My subs aren't working when using bluetooth
My subs work when it's playing on the tuner or the ipod is plugged in but will not work when it is playing Bluetooth audio
2 Suggested Answers
SOURCE: kenwood mp335
i was reading that there is a 'mute' wire, that when touches -12volts, will mute the stereo. just a thought.
Posted on Oct 06, 2007
I have a Clarion VZ401. I have a couple subs hooked up to it and the subs only work with the radio tuner. It will not work with Satelite Radio, Bluetooth, or IPod. Can this be corrected?
That is an interesting issue. I recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information proves beneficial.
May 30, 2015 | Clarion Car Audio & Video
When listening to music via Bluetooth On my kenwood DNX8190hd, my subs don't work. That being said, the subs do work in any other mode. Radio iPod etc. What is the solution
go to Bluetooth settings and turn on the all speakers setting and all will be good... also use accessory turn on from the radio for amp turn on. unless kenwood changed something the remote turn on is weak and doesn't always work
Jul 25, 2012 | Car Audio & Video
My ipod touch wont play music on my docking station it used to it still charges it help
I had this problem too. You're going to have to restore it with iTunes.
  1. Plug your iPod into your computer and sync it with iTunes.
  2. Go to the "Summary" tab and choose restore.
  3. Let iTunes do its thing and try it on you dock again.
If that doesn't work then I would suggest taking it on and off of the docking station until it works. I know this sounds really primitive but this is what I ended up doing and now it works fine.
One last thing, if you recently upgraded your iPod's firmware then that might be what is messing you up. Sometimes docks aren't compatible with the newer firmware Apple puts out so you might have to buy a new dock unfortunately. But if your iPod was jailbroken on a past firmware you can use this video to downgrade it to when it worked with your dock.
Apr 09, 2011 | Apple iPod touch
When i have the stereo on radio my amp/subs work fine, but as soon as i switch the mode to USB ( built in ipod connector) it cuts out the power to the amp/subs. It only works on tuner mode (radio) why?
use the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on) to turn your amp on. the power antenna wire shuts off when leaving tuner mode.
Mar 02, 2011 | Sony DSX-S100 Car CD/ MP3 Player
The tuner works fine, all the speakers play including my sub. When I put in a cd, only my sub makes sound, and when I go to the ipod no sound comes out. However When I go to the zone control and select the...
are you using more than one amplifier? it sounds like you may be using the blue wire to turn one amp and and the blue/white to turn the other one on. use the blue/white only. the blue wire is antenna remote and turns off when not in tuner mode.
Jan 09, 2011 | Kenwood DDX516 Car Video Player
How to set it to play with and Ipod
After researching your model DEH-P470MP, it appears that to use an iPod, you need an adapter that plugs into the rear port of the unit intended for a multi-cd changer connection.
If you have one installed and it's not working, I would check the connection on the unit. Make sure the cable is firmly seated in the port and then check the cable and also check for any fuse in the line to make sure it's not blown out.
Also some of the earlier models of ipod adapters aren't compatible with the newer generations of ipods. There are aftermarket adapter plugs that will allow your ipod to charge/play off these earlier decks/adapters.
May 29, 2010 | Pioneer DEH-P470MP Premier In-Dash...
Sound works on tuner but not cd
I have subs in my system but the tuner only works for sound. The cd nor the ipod will make no sound other than the subs.
Jan 09, 2010 | Clarion MAX385VD Car DVD Player
Vrv785bt- No sound except tuner
sounds like u have a premium sound system. what u need to do is take ur blue/white remotewire to ur blue power antennat that should activate ur factory amp.
Apr 16, 2009 | Clarion VRX785BT Car DVD Player
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
VM9311TS Subwooofer problem
you wired the remote wire up to the solid blue wire on the dvd player.....you need to put it on the blue wire with a white stripe......that should make it come on for everything....the solid blue wire is if you have motorized radio antenna. it turns it on
Sep 04, 2007 | Jensen AM/FM/MP3/DVD/CD iPod-Ready...
Kenwood DDX470 - DVD receiver - display 6.1 in - in-dash unit - Double-DIN Logo
21 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
