Question about Whirlpool Washing Machines
Whirlpool w10117767a error f-
Error message F- while washing towels. tried drain/spin. same error.
SOURCE: What do I do for dL and F error message?
same problem..for a couple months I could get it to work intermittently but finally gave in and the repair guy is here putting in a new control panel. expensive sorry to say.
Posted on Jul 18, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet-Error code F 02/wont spin and drain
Yes...the "F02" error code is a "Long Drain" error. The washer will not spin if it cannot drain the tub, first. The following link explains how to diagnose and correct the problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In most cases this is nothing more than a clogged drain pump. Folow the steps outlined in teh link provided on how to check and clear the drain pump and drain lines. Now...it does not take much to damage these pumps. If anything has been left in the pump for a significant period of time it can cause irrepairable damage to the pump impeller and/or motor. The result: a drain pump that MAY run, but won't actually pump anything.
If this is the case, you will need to replace the pump. Replacements can be obtained at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Pump and Motor Parts" heading for item number 10. This next link will provide you with the steps necessary to replace the pump (if required):
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 09, 2008
  • 26 Answers
SOURCE: whirlpool duet hf error
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTES:
  • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
  • If the error remains on the display, and all of the other conditions above have been checked, call for service.
Posted on Dec 20, 2008
quatlew
  • 139 Answers
SOURCE: whirlpool cabrio giving error message LD-what is wrong
Long drain error can be caused by something plugging the drain hose or a kink. Tale it off th drain while it is pumping out and check for a good flow. If the hose is ok the pump may have an obstruction causing low flow and it will have to be cleaned out.
Posted on Mar 18, 2010
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Whirlpool duet washer error code f-02
Error F-02 is a slow drain problem. Remove lower front panel. You will see a circular door. Be prepared for a lot of water and junk, maybe keep some old towels ready. Open, clean out, check pump which comes right behind it - see that blades rotate freely; refit carefully. You are done, for the next six months or so, depending on usage.
Click if helped
Apr 14, 2013 | Whirlpool Washing Machines
What does F- mean
First, remove the lower panel and clean the drain filter. Try to run it after that and post back your results. BE AWARE! When you open the filter there will be a good amount of water that will come out so have plenty of towels handy or a wet dry vac at the ready!
Nov 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
@my washer does not always spin the clothes and has a f21 error message what can I do?
check and make sure that your drain hose is free. make sure its not kinked. ad that is doesn't go 96" above the floor. If there is no problem with the drain hose then you may have something jammed in your drain pump. Remove the bottom panel of the washing machine. the drain pump will now be visible. turn the tab on the drain pump so you can gain access to see if there is anything inside. there will be water flowing out so you should have some towels and a small container handy.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool cabrio giving error message LD-what is wrong
Mar 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
I get the error code S02 on my Duet washer. It
02 is a slow drain,
yopu can check your pump
take off the back wall and hoses,, have towels ready
you will loose water,,
inspect the inside of the pump and all hoses
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
F-21
replace the contol board
Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
65 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
