Question about Toshiba 27A34 27" TV
PDF manual for 27A34 - Toshiba 27A34 27" TV
    Sergeant:
  • 266 Answers
Toshiba 27a34 27in. I am getting white lines at top of screen. At first they would slowly disappear, but now they are staying.
Easy fix if you have a solder iron, solder, and a 100uF, 50v capacitor. This picture shows the capacitor (Green) after replacement. This symptom is called "Fold Over". Simply replace the shown capacitor with the same value and you will be all set. Project time < 30 minutes. -milkburp9e9db24.jpg
Jan 31, 2010 | Toshiba 27A34 27" TV
Television Picture Height
Please view the solution here: http://www.fixya.com/support/t4019796-toshiba_27a34_27in_am_getting_white
Dec 31, 2009 | Toshiba 27A34 27" TV
Lines at the top of the screen. Can I get rid of
Please view solution here: http://www.fixya.com/support/t4019796-toshiba_27a34_27in_am_getting_white
Oct 29, 2009 | Toshiba 27A34 27" TV
Input channel
sadsoldinf33 -
You keep pressing the TV/VIDEO button to switch between input modes.
Here is your manual in PDF: http://www.tacp.toshiba.com/tacpassets-images/models/27a34/docs/27a34_om_e.pdf
(See page 24 of the manual).
Thanks,
videoman7
Aug 07, 2009 | Toshiba 27A34 27" TV
Programming remote to toshiba Tv
Depending on the universal remote you can usually program the remote without knowing the codes. One way is to turn on the television, then follow the basic programming instructions for the remote, but instead of entering a code, hit the power button over and over again until the television turns off.
I hope this helps.
Ken
May 27, 2008 | Toshiba 27A34 27" TV
Set up an a Panasonic TZ-20L3Z
Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
Aug 19, 2007 | Toshiba 27A34 27" TV
Setting the channels
You can download the manual from the link below: http://safemanuals.com/download_94794.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Guide to setting the channels
Hi Chet, At most that I can give you is a generic procedure but should work also in your unit other than the names/terms would probably be a tad different. Using your remote, press menu, select setup. You may have to select whether you are using cable or aerial. Aerial antenna could be name Air or Std. Normally there would be a search function or add channels or memory + or something like that. Am not sure but you may have a save butoon also but not always. Hope this gives you some idea. Pls post back how things are or if you need further information. Good luck and kind regards.
Toshiba 27A34 27" TV Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
