Question about LG 42LD550 42 in. TV
EBU60934502 where is the problem with the main board
I have a bad main board on a LG 42" TV ( LD42550 ) and I have an extra main board from the same TV but its 32", will it work?
Unfortunately they aren't interchangeable, sometimes power boards are in a situation like this but with main boards you need the same number...the 3642 stands for 42" (last 2 numbers) and the 3632 is for a 32"
Oct 22, 2017 | LG Televison & Video
I have LG 42LN5300 which is reading 230VDC at led + plug and no back lights. All other voltages going to main board are OK, I changed main board because of flickering on and off screen, so is it MB
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 20, 2017 | LG Televison & Video
What would cause a black screen on vizio LCD Tv? I have sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 14, 2017 | Vizio Televison & Video
LG tv 55GA6400 has sound but picture keeps going black after a minute or so.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 13, 2017 | LG Televison & Video
Vizio tv 37" picture started to get darker
Jan 11, 2017 | Vizio Televison & Video
No audio or video flashing 2 power 1 opc after relay latch?
Yes,this problem are related to the main Tuner signal board,must change the main Tuner signal board,to solved this problem.Put back your old power supply board too might be still good,but some time the power supply board must have to be replace too,becaused it got corrupted by the data from the main CPU from the main Tuner signal board.
Feb 20, 2013 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My Vizio VW42L will not power on. No backlights, no power from pson pin. has 5v stand by power on power to main board. no 12 or 24 volt power. has a new power board and inverter boards.
The main board is defective the power on command originates from the main board and thats what gives the signal to start powering up the set. Replacing the main board should solve the issue. You can get the main board from www.tvcircuitboards.com
Jan 02, 2013 | Vizio L32 32 in. LCD HDTV
I need to purchase a main board for a Proview, MDL # HV205 LC TV.
Tries Websites Shopjimmy.com,Ebay.com should have this reburbish Main Tuner board.
Apr 14, 2010 | Proview HV-207 20 in. HD-Ready LCD...
Niko OTP-3211W 32' Mainboard Needed
We don't do email on Fixya and no idea who Jerry is. Keep all replies in the same post by clicking COMMENT under the name of the person you are replying to. Fixya gets 7 million questions a year, so the likelyhood of 'Jerry' seeing are impossible.
Here are your mainboards, 50 bucks.
Niko OTP-3211W TV Parts - ShopJimmy
www.shopjimmy.com/niko/otp-3211w
Niko 21VT3MB0224 (DA0VT3MB6F2) Main Board for OTP-3211W. $46.95. Part number is found on sticker. Set In-Stock Alert · Niko 24VV3EB0003 (DA0VV3TH2B2) PC Board. Out of Stock. Black Friday Deal. Cyber Monday Deal ...
Niko 21VT3MB0127 (DA0VT3MB6F2) Main Board for OTP-3211W
www.shopjimmy.com/niko-21vt3mb0127-main-board.htm This Niko 21VT3MB0127 (DA0VT3MB6F2) Main Board for OTP-3211W (21VT3MB0127) works for these TV models: Niko OTP-3211W.
NIKO 21VT3MB0224 Main Board for Otp-3211w ' eBay
https://www.ebay.com > ... > TV Boards, Parts & Components Find great deals for NIKO 21VT3MB0224 Main Board for Otp-3211w. Shop with confidence on eBay!
Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit ...
www.ebay.com/itm/Niko...OTP-3211W...Main-Board-MotherBoard...-/28218366183... US$49.99 - ‎In stock
This main board was pulled from a working TV with a broken screen, please refer to the pictures. The last 2 pictures are of the TV this was removed from. This sale is for the Main Board and cables shown. I only accept Paypal. Paypal payment must be made within 2 days of end of sale. I will ship within 3 business days of ...
NIKO MAIN BOARD 21VT3MB0224 REV:F FOR MODEL OTP-3211W ...
www.ebay.com/itm/NIKO-MAIN-BOARD...REV-F...OTP-3211W-/172511137409 US$39.95 - ‎In stock
WE TEST ALL OUR PARTS AND GUARANTEE THEM NOT TO BE DOA (DEAD ON ARRIVAL). IF YOU EXPERIENCE A PROBLEM WITH THE PART YOU RECEIVED PLEASE CONTACT US WITHIN THREE (3) DAYS OF RECEIPT AND WE WILL WORK WITH YOU TO CORRECT THE PROBLEM EITHER BY EXCHANGE ...
Amazon.com : Niko - Niko OTP-3211W Audio Board DA0VV3AB2C9 ...
https://www.amazon.com/Niko-OTP-3211W-Audio.../dp/B00SVM5OR8 TV Brand: Niko TV Model: OTP-3211W Part Type: MAIN BOARD Board Numbers: DA0VV3AB2C9, 23VV3AB0004 Part Number: 23VV3AB0004 Specifications: Look for 23VV3AB0004 in your part to verify part number and compatibility. Other Specifications: Part number can be found on the sticker. This board has been ...
Main Board Otp ' TV Repair Components For Sale
https://tvrepaircomponents.pw/niko/sale-main-board-otp__samsung_power.html
6 days ago - Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit. $45.99. Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit. Niko 32" OTP-3211W. Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit. $49.99. NIKO MAIN BOARD 21VT3MB0224 REV:F FOR ...
Otp Niko Main ' TV Repair Components For Sale
https://tvrepaircomponents.pw/niko/sale-otp-niko-main__samsung_power.html
6 days ago - Up to 90% off brand name Tv Part only from your leader in online shopping including discounts on niko, niko main, board niko main, niko main otp, board otp ... Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit ... Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit.
Niko OTP-3211W Main Board DA0VT3MB6E4 21VT3MB0224
www.myshoptvs.com/.../7058-niko-otp-3211w-main-board-da0vt3mb6e4-m9204.ht... Find the best TV part Niko OTP-3211W Main Board DA0VT3MB6E4 21VT3MB0224 at the lowest price online.
22VV3IB0018 Niko TV Module, signal, DAVV3PI12C4, OTP-3211W
www.tvpartstoday.com/22VV3IB0018-Niko-TV-Module...board.../22vv3ib0018.htm Part Number: 22VV3IB0018. Board Numbers: DAVV3PI12C4. TV Models: OTP-3211W. Type: Signal board. ... 22VV3IB0018 Niko TV Module, signal board, DAVV3PI12C4, OTP-3211W Email A Friend ... MODEL NUMBERS: OTP-3211W PART TYPE: Main Board TV TYPE AND SIZE: LCD, 32" MFR PART NUMBER: Niko ...
Niko OTP 3211W main board Google Search
Dec 30, 2017 | Niko OTP-3211W 32 in. LCD Television
LG 42LD550 42 in. TV Logo
82 people viewed this question
Computer Repairing
Computer Repairing
