Question about JVC AV-56WP30 56" Rear Projection Television
It powers on and has sound but cannot see the picture clearly. The picture on the TV is like in the middle of the screen and very small and blurred. 2005 56" Jvc I'Art Pro 1080i HDTV AV-56wp30
  • JVC Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
6It powers on and has sound but cannot see the - 0dcec37.jpg class=
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your converIt powers on and has sound but cannot see the - 0667c5f.png are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid chaIt powers on and has sound but cannot see the - 9e7eb5b.jpge how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV sIt powers on and has sound but cannot see the - 2c07611.pnguid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 22, 2009
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
Picture has a sag in the middle, blurring the sides of the screen.
okay that sounds like a problem in the horizontal circuit and vertical circuit.the module of those section wants to be replaced.only a tech can do the repair.look for a tech to repair your tv
Sep 25, 2011 | Samsung HCN653W 65" Rear Projection...
When switch on television picture blurred and image not clear. after some time around 20 minutes image starts to clear and tv plays normally, sound is ok
You have to check your capacitor may some of it have leak. May your picture tube have already a problem. Just check first the capacitor filter on the flyback that supply the power for the CRT socket of the picture tube.
Aug 13, 2011 | Panasonic TC-21Z88R 21" TV
My Sony Bravia tv has a problem with the screen getting dark on the right side. Sometimes the screen is normal, and then sometimes it goes dark and/or red. There is a small square (2 inches) that has a...
This tv have a problems with a board that call T-CON decodering board.This T-CON decodering board sit at the bottom in the middle of the LCD screen panel.This T-CON decodering board,decodering the tv incomming broadcasting tv signal before it go into the tv LCD screen panel to produce pictures.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Apr 23, 2011 | Televison & Video
GET SOUND BUT NO CLEAR PICTURE ONLY HORIZONTAL LINES form bottom to middle black blur lines
Video output section of your tv is in trouble. Either it not gets proper voltage [low voltage if voltage is there]; or video output Ic or transistors whichever used may got damaged. Never switch on the tv in this condition; that picture tube may get damaged. Get it repaired soon.
Oct 14, 2010 | Philips Magnavox 20MT133S 20" TV
LCD screen is extremely blurred
It is probably not the LCD itself, but an element that is protecting the LCD is bent out of shape.
Jan 16, 2009 | Vivitar ViviCam 5386 Digital Camera
Gray picture
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
Sep 16, 2008 | Samsung DynaFlat TX-P3064W 30" TV
When sound & picture finally comes on the picture is pink and in the middle of the screen
This is a common problem with this model. The site www.magnavoxhelp.com has a chip kit to fix the no audio/video and video shrinking problem.
Sep 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
Image went out and now i see small blur in the middle
does the blur goes across set? Or is it round in the middle?
Oct 07, 2007 | Panasonic PT-53TW53 53" Rear Projection...
JVC AV-56WP30 56" Rear Projection Television Logo
115 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
