Question about Teac Audio Players & Recorders
I want to adapt my 30gb Ipod to my Teac AG-D8900 receiver
  • igrono May 18, 2009
    I tried the adapter I have (Red and White RCA jacks to Ipod headphone jack) in all the audio jacks and it doesn't work. It worked on other receivers
    I would like to adapt my 30GB Ipod to my Teac AG-D8900 receiver. I tried R & L red and white RCA plugs from the headphone output in the Ipod in the different audio jacks and it did not work
  • 11,896 Answers
If this worked on other players but not the Teac, try using other input jacks on the receiver. Also make sure the receiver is on the correct input channel.
Otherwise I would try another cable.
You can also try using another device with the receiver to figure out if it's the ipod, wires, or bad input jacks on receiver. If it's the inputs on receiver, new capacitors will have to be installed.
Posted on May 18, 2009
    Brigadier General:
  • 3,917 Answers
You need to plug the cable from your iPod into a L and R audio jack, forget the video jack. I recommend using a spare set of jacks on the rear of your receiver. Jacks on the front are typically used for video devices that you do not want to be a permanent part of your system (like a camcorder - one video jack, one jack each for L and R audio).
P.S. You will get the best audio quality from your iPod if you go out of the line-out jack in the dock. Going out of the headphone jack on the iPod provides inferior results. Thanks
Instrutions for connecting system to a sanyo tv no hd or plamas
Left and Right audio "output" into any open left and right Input on receiver.
Mar 23, 2011 | Teac AG-D8900 Receiver
Can I hook a turntable to a Teac AG-D8900. Where do I input?
only if the unit has a PHONO input never plug a turntable into any other jack as teh voltage is different.
I have seen an adapter so that you can plug a turntable into an ordinary input I believe Radio Shack but that was along time ago try ebay
Jan 08, 2010 | Teac AG-D8900 Receiver
Teac AG D8900 II sub woofer not working
click on the blue "teac sub woofer" link top of page, solution is in my response to another with same problem-that is at least 3 of us with this now.
JS
Dec 26, 2008 | Teac AG-D8900 Receiver
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
Subwoofer
cheak all setting woof out ect cheak wires cheak for i pod updates
Feb 01, 2008 | Teac AG-D8900 Receiver
Connecting An Equalizer
you will need 6 equalizers or 3 stereo equalizers.
connect the 5.1 analogue outputs of your media player (DVD Player) to the equalizer and then connect the analogue output of the equalizer to the AVR.
now you can equaize the sound for extra boost and cut.
Warning: it is not recomended to do so unless you have a powerful amp and high quality and higher wattage speakers, as equalizers are ment to be used mainly for entertianment zones and outdoors in professional applications.
the home speakers annd electronics are not really capable of taking such electronic stress as they are designed to work indoors in a confined space.
but if you are confident go ahed.
Jan 21, 2008 | Teac AG-D8900 Receiver
Teac AG-D8900 Receiver - No power
Hello meml,
Since you mention that there is no standby light at all, the problem could be related to the receiver's main power supply, which is not uncommon for a unit of this age.
Now, if you decide to take the unit to a repair shop, do not let the cost of repairing the unit be the only factor that determines if you bring it back to life or to use it as a door stop.
Consider the replacement cost compared to the repair cost, also, have in mind that newer receivers can supply more output power per channel and have more advanced decoding technologies among other features. Hope this helps your decision. Let me know.
cancerags.
Apr 11, 2007 | Teac AG-D8900 Receiver
Setting Up The System
You can find the requested details at: http://www.teac.com.au/file/product_manual_408.pdf
Mar 09, 2006 | Teac AG-D8900 Receiver
Protect
You may have shorted the speaker wires. Remove all wires from the output connections and make doubly sure no strands are left there. Turn volume to zero and turn the receiver on. If the problem persists, you probably fried the output stage. Have it repaired.
Jan 22, 2006 | Teac AG-D8900 Receiver
42 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
