Question about Samsung HLS4266 TV
There are faint black horizontal lines and outlines around objects
Objects seam to be highlighted
  • 1030 Answers
SOURCE: Samsung hl-p6163w
ussally when u get coloerd outlined this idicates ether a convergence or a focuse problem.. the green convergence has become shifted. not lineing up with red and blue.. this also could indicate a green crt problem.. my advice is to get a tech to check it out.. it could be a simple adjustment or a whole new green crt
Posted on Dec 18, 2007
Shuttle83
  • 1139 Answers
SOURCE: colors
Hello giveitup,
This sounds like a convergence problem which means that your convergence amps have malfunctioned. You can change these out yourself, however you will also have to change out all of the biasing resistors connected to the amplifiers. To do this:
1) Unplug the TV and then get a schematic of the TV I use http://www.servicemanuals.net or http://www.manualsparadise.com
2) On the schematic locate the STK329-xxx series IC packs (usually attached to a large heat sink)
3) determine if the STK329s are 110, 120 or 150.
4) if the STK329-xxx's are 110s replace with 110s (forget that upgrade stuff it is a hit or miss game that I don't believe you want to get into), if they are 120s replace with 120s and so on.
5) Now to replace the STKs: remove the module from the TV and unsolder the old STKs along with the bias resistors, and replace them with the new ones (be sure to apply heat sink paste to the STKs when attaching them to the heatsink)
6) make sure there are no short circuits form your soldering job.
7) Reinstall the module and then turn on the TV.
8) do an auto-convergence test and then things should be back to normal.
Now if you think you can do this have at it, if not I would suggest that you have it done by a qualified TV technician.
Thank you,
I hope this helps,
Shuttle83
Posted on Nov 01, 2008
  • 1121 Answers
SOURCE: distored picture and a rainbow aura around objects in the pictur
this CRT TUBE internal Problem, first use CRT Rejuvenation Device. If dont repair you must change CRT TUBES
Posted on Oct 31, 2009
rylee_smith
  • 8619 Answers
SOURCE: cant get the color adjusted to the right setting
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 10, 2010
rulds2008
  • 3866 Answers
SOURCE: I have a Samsung HLN5065W DLP, It started by going
Sounds more or less a color wheel issue, what are the other symptoms?
9 times out of ten the color wheel will do this and that is what it seems to be,
let me know and update me with any other information
please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Sep 09, 2010
I get into a game of black ops, and the gun and some objects look shiny and silver, but other people in the game are just black outlines?
What's happening here is the dynamic charter feed from the G.P.U. has lost
communication to map/layer feed . so you will get Checker boarding and boundary
layer ( outlining ) The broken conections are near the corners of the G.P.U..This
failure is easily correctable with a solid reflow and a proper compresion load in
the effected areas to prevent it from happening again.
A good reflow of the G.P.U.
and a proper re clamping of the heat sink, average cost 60.00-90.00
Shop around for someone local to do the repair. Get at least 90 day
money back grantee.
Rob
Apr 01, 2011 | Microsoft Xbox 360 Console
5D-Mark II screen flashes with reflecting objects
No. It's simply a menu setting to show you where potentially overexposed highlights in the final image will be. The function can be set to show shadows or highlights.
I don't currently have a manual to hand, but if you can't find how to turn it off in your own manual then report back and I'll have a thorough rummage for one.
May 25, 2010 | Canon EOS 5D Mark II Digital Camera with...
When using flash, pics ALL white!! overexposed!!
CCD FAILURE
CALL FUJI for FREE repairs u are eligible i got mine repaired free it is a known problem
Regards
Zohail
May 27, 2009 | Fuji FinePix S5000 Digital Camera
HP z2100 horizontal lines where the text or object are
Check for updated firmware and drivers. Also, if all your object and text or black try changing them to color and see if that helps, maybe there is something wrong with your black printhead, the black may not be used when printing photos, the printer may be using process black for photoes and real black for black text and objects.
Oct 08, 2008 | HP DesignJet Z2100 InkJet Photo Printer
Red horizontal lines won't line up.
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 06, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Samsung hl-p6163w
Nov 16, 2007 | Samsung HCN653W 65" Rear Projection...
Samsung HLS4266 TV Logo
16 people viewed this question
Jerry Greenberg
Jerry Greenberg
