Question about Husqvarna Huskylock Computerized 936
Husqvarna problems I am getting an "overload" message. I have re-threaded the overlocker, but still getting same message. It will not sew. Could you help me please? Cheers, Beverley Partridge
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
akylas
  • 26 Answers
SOURCE: thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
Posted on May 28, 2008
  • 201 Answers
SOURCE: Husqvarna bobbin thread jamming
Make sure the bobbin thread "clicks" into the tension slot. However, thread nests underneath are usually caused by the top thread, not the bobbin. Make sure your thread is seating itself in the top tension disks. To do this, put the spool on the machine, pull off about 12 or 15 inches of thread, then hold this thread down with one finger on your right hand as you take the thread tail through the threading path with your left hand. When you get to the needle, tug the thread (still holding it down up top) to be sure it seats in the tensions disks. You must also have the presser foot UP while you do this to ensure that the tension disks are open. Watch the first thread guide after the spool as you sew to make sure the thread is not jumping out of there (a common problem with Des1 machines, fixed with SEs - no comfort to you and me!). I have put a small piece of tape across there with the end turned back on itself so no sticky bit is going to catch on the thread.
Posted on Mar 21, 2009
  • 10 Answers
SOURCE: Husqvarna Sewing Machine starts sewing when power switched on
The problem is probably the foot control. The little wires wrapped around the insulator have broken and are shorting against each other or the cord itself has a short. You can purchase an aftermarket foot control at your local shop, this is the cheapest way to try first, if that does not correct the problem replace the cord.
Posted on Jun 30, 2009
  • 371 Answers
SOURCE: How to thread my sewing machine? Husqvarna Classica 95
Suggest you contact an authorized Husqvarna Viking dealer. They can order you a user manual. Authorized dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Brief description of probably how to thread from looking at a picture of a Classica 90 machine which should be similar -
Thread sits on spindle on backside. Pull thread straight across to upper left backside and fit in the metal guide. It should pull easily with only a little resistance. Pull thread forward across top toward you. Let thread fall between the metal disks (doesn't matter which one if more than one) and pull thread straight down. Pull thread slightly to the left to fit under a hook of some type and back up to fit through the large hook that moves up and down when the handwheel is turned. Come straight back down to needle and thread through eye of the needle. Just above the needle should be a thread guide (sideways hooking looking metal piece), slip the thread through it to hold thread close to needle. Hope this helps. Otherwise a local authorized Husqvarna Viking dealer will be glad to help you. Good luck.
Posted on Sep 25, 2009
How to thread a husky overlock s-25 for coverstitch from the begining
check your manual for instructions and or see your Viking dealer for help.
Jun 29, 2014 | Husqvarna Huskylock Computerized 936
Huskylock 936 will not form a 4-thread overlock stitch
It may be difficult to solve a computer controlled machine with as many options as the 936 serger. Stepper motors control many of the functions. You can check out this video I made 4 years ago to get an idea of where to look.
Nov 19, 2013 | Husqvarna Huskylock Computerized 936
Need a Husqvarna huskylock 550D overlocker manual
try checking with husqvarna website about a manual or threading diagram
sewingpartsonline.com
sewingmanuals.com
May 07, 2012 | Sewing Machines
My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
Good evening madam
It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
good luck
Kolbrun
Feb 26, 2012 | Husqvarna Huskylock Computerized 936
4 thread overlock --right needle skipping stitches randomly. I've put in new needles, changed threads, etc. The stitch is beautiful just skipping a stitch randomly when sewing.
Sounds like the loopers are slightly out of line or the needle bar is twisted. Unfortunately these adjustments are not easily made. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 13, 2010 | Husqvarna Sewing Machines
I have a husky lock 234D serger and no manual. how do i use 3 thread overlock? which threads do i use?
To use a 3 thread overlock, thread the overlooper; the underlooper and then use ONE of the needles. Removing the RIGHT needle will produce a 5mm or 1/4" seam. Removing the LEFT needle will produce a 3mm or 3/16" seam.
Dec 17, 2009 | Husqvarna Sewing Machines
Thread keeps breaking
Check first that you are using premium thread (not the cheaper type that you'd use in an overlocker/serger). Breaking thread could be because of one of the following reasons -
the upper tension is too tight, the machine isn't threaded correctly, the thread doesn't suit the fabric (I had the problem when sewing an item the other day and changed from cotton thread to polyester and it stopped breaking). In your instruction manual check at the back for a troubleshooting section where it should be listed with some solutions.
Jul 08, 2009 | Husqvarna Husky 165
My huskylock430 is threaded but it will not overlock i bent a needle & its like somthing was put out of place just wont chain
if its not overlocking its not threaded right, but if the needle is bent at all it needs to be replaced and can cause stich malfunction or a piece of needle to fly randomly when it fully breaks! you can download the threading diagram if you google your machine... good luck
Feb 26, 2009 | Husqvarna Sewing Machines
Thread wont overlock
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
41 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
