Question about Samsung HC-P5241W 52" Rear Projection HDTV-Ready Television
Picture turned pink
I have a 52 inch samsung projection hdtv. All the sudden the picture lost quality and turned pink/red... We tried to adjust the picture but it didnt help...
  • Brett Steward Jun 16, 2008
    Any estimate on how much it costs to repair this problem? I have the exact same green...lots of pink.
    Problem Solver:
  • 61 Answers
This all of the sudden happened if so you may have lost the green alot of times yoiu can fix the CRT drive Brd there is a video amp ic and a resistor that can be replaced or yo can replace the whole Brd a little harder to do than just replacing the parts on the Brd
Posted on Jun 11, 2008
Sound, but no picture
If before it was going rather bright red or a version of that--it is related to the circuit for the red picture tube this set uses---the tube itself or the circuit board that plugs onto the end of that tube.
If bright red, green or blue screen set will detect too much current being drawn and blank or turn tubes off; not likely a do it yourself repair and this set is prone to this and many other problems---Just Google the model number with "problems" and see what I mean.
Apr 19, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
WD-52525 52 in. Rear Projection HDTV Television: my mitsubishi projection tv has a distorted pictur...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
May 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
07 sony 32"hdtv trouble...
sounds like you have a bad lamp maybe a bad color weel to so be careful
May 16, 2009 | Zenith D52WLCD 52" Rear Projection...
HDTV 52 inch RCA projection
The red picture tube is shorted. Huge job! Maybe not worth doing.
Apr 09, 2009 | RCA HD52W151 52" Rear Projection HDTV
Picture NOT Alined
Use the zoom for picture adjustment.
Feb 08, 2009 | RCA D52W23 52" HDTV CRT TV
Pink hue
Remove speaker grill, manually adjust red drive untill red is normal.
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My screen have some red lines
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt replacement is probably not economical to repair.
Jun 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Samsung HC-P5241W 52" Rear Projection HDTV-Ready Television Logo
142 people viewed this question
Jerry Greenberg
Jerry Greenberg
