Question about Rival 38601 Smart Pot 6-Quart
I just put some precooked, still warm food in my crockpot. I tried to set the control to warm so I could serve later. Can't get warm to turn on. How can I?
To better diagnose your problem I need more information. Does your crockpot have a light that indicates when your heating element is ON? If so, increase the temp of the crock pot knob to find out if the LED light comes on at all. (you may also wish to make sure the unit is plugged in and the outlet is working properly.)
Since all crockpots work using a temp sensor, it could be that the temp of the food is still warm enough that the crockpot thermostat is not calling for additional heat to maintain the temperature. If you can, remove the crockpot liner and let the unit cool somewhat to allow the thermostat to return to room temp and reset.
If this doesnt solve your problem, chances are that the sensor/thermostat may be faulty or one of the circuits to the heating element may have overheated causing a wire to become disconnected or burn out. Appliances can wear out with use or age and even power surges can 'fry' delicate circuitry.
Posted on May 18, 2009
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    Which will provide the lowest heat? low 10 hours or warm setting. Thanks
    The WARM setting is the lowest heat. Here's a quote from the user manual:
    "WARM is ONLY for keeping already cooked food at the perfect serving temperature. DO NOT cook on the WARM setting."
    This is because at the WARM setting, the temperature doesn't get hot enough to kill food-borne bacteria.
    Jan 18, 2011 | Rival 38601 Smart Pot 6-Quart
    My crockpot burns food, even food that is still frozen when put in the crockpot. I made a pot roast in my crockpot and it was frozen in the beginning. I added two cups of frozen broth and set the...
    Your crockpot heat unit is overheating. Return it to the store you purchased it at or contact the manufacturer. My Rival did that and I contacted the company and they sent me a new one.
    Sep 29, 2010 | Rival 38501 Smart Pot 5-Quart
    I don't know how to use it or what to use it for.
    Go to any library or online and type in slow cooker recipes. I use my crockpot 4 times per week to make the best food in the world. I am a professionally trained chef and still rely on my crockpot for the best recipes. You cannot beat just throwing everything in a pot, turning it on and eating it 6-12 hours later with no work!
    Sep 08, 2010 | GE Crock Pots & Slow Cookers
    Rival crockpot knob
    Try the hardware store. Look at the dimmer knobs.
    Jan 17, 2009 | Rival 3355 5-Quart
    Rival 38601 Smart Pot 6-Quart Slow Cooker can't get to to go to warm
    Here is the manual for this cooker; http://www.crockpot.com/manuals/38601-C_English.pdf page E4 and E5 tells you details of programming/timer/temperature. Check through everything and see if you can figure anything out. after cooking, the unit should automatically switch to warm mode, if it isn't doing this then unfortunately i think it needs a replacement control board - probably not worth doing. If you want to give it a try then post again and we can try and source you the bits Hope this helps :)
    Mar 16, 2007 | Rival 38601 Smart Pot 6-Quart
    All Three Lights Blinking
    We have their 6 quart Crock Pot. Same problem cited here!
    We have found that, if you press both the (Low/High/Warm) AND the (Off) buttons at the same time, the controls will revert to the proper state. It has worked for us on several occasions so we trust it and have found no "adverse results"!
    Hope this is a help to others.......
    Jan 28, 2007 | Rival 38651-C 6-Quart
    Rival 38601 Smart Pot 6-Quart Logo
    267 people viewed this question
    Top Rival Crock Pots & Slow Cookers Experts
    Jerry Greenberg
    Jerry Greenberg
    charles
    Irene Tulloch
    Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
